Old 05-25-2011, 05:51 PM   #1
Hot water switch
Has anyone replaced the on/off switch for the electric hot water heater ??
I have a 2006 Cherokee Light 5th Wheel. Problem is to get to the back of the switch. No access from outside and inside it is behind the hot water tank
Any help or suggestions greatly appreciated. Hate to have to remove the hot water tank.
ewm220 is offline   Reply With Quote
Old 05-25-2011, 06:28 PM   #2
MtnGuy's Avatar
I replaced was bad from the factory. It has 2 tabs that need to pushed in on each end. Since the old switch is going in the trash anyway, push a small screwdriver behind the long end, and push the tab down while prying with the screwdriver. The other end is easier, since the 1st end is already done.
Here is a picture of the switch so you can see how it is made:
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
Old 05-26-2011, 06:46 AM   #3
KyDan's Avatar
IF your water heater is on a separate circuit breaker you can
shut it off at the breaker and forget the outside switch.
If the switch is bad then that's another story.....
(mine is stuck ON but I don't care as long as it heats water....)
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 05-26-2011, 08:59 AM   #4
jimh's Avatar
mine froze also. i use the inside breaker. i have sprayed wd40 on a couple other switches with success.
i used wd40 to clean tv tuner contacts in my younger days.
jimh is offline   Reply With Quote
Old 05-26-2011, 10:04 AM   #5
I added a switch on mine in order to turn on and off from inside. I leave the switch on th water heater on . The cord for mine plugged in under my entertainment area. I removed a panel and wired the switch in line.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 05-26-2011, 05:13 PM   #6
Hot water switch
Thanks to all for your prompt replies.
I found the idea of poping out the switch with a screwdriver worked like a charm. Had it out in 5 minites.
Problem solved !!
Thanks again.
