Old 08-26-2019, 01:20 PM   #1
How to fix
This weekend when I was disconnecting my battery while packing up I notice this. I taped it with duct tape for the time being until I get a plan of action on how to find. Luckily we aren't expecting rain til next week. Click image for larger version
ID:	213416Click image for larger version
ID:	213417Click image for larger version
Bedlinedf250 is offline   Reply With Quote
Old 08-26-2019, 04:06 PM   #2
I'd just use some liquid nails, or silicone adhesive of some sort. Be careful not to squeeze it out above the faux diamond plate. It might not look the best then. Then go back with some clear silicone on the top edge, to ensure it's sealed up good.
Me, the wife, & 2 daughters (9 & 4yrs old)
2019 Palomino Puma QBSS
2015 Silverado LTZ / Z71 w/ many upgrades
GXPWeasel1 is offline   Reply With Quote
Old 08-26-2019, 04:13 PM   #3
cboss's Avatar
And maybe finish it off with some Flex Tape.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is offline   Reply With Quote
Old 08-26-2019, 07:38 PM   #4
Do like I do when "bedding" a rifle action in a stock. Put down a layer of tape (heavy 2" wide vinyl Pipe Tape is my fav.) right along the edge of the body where the fake diamond plate ends. Any glue squeezed out will only stick to the tape. When set/hardened just run a razor blade along the top edge of the fake diamond plate, enough to cut through to the level of the tape, and then pull up the tape. Excess glue will come off with tape.
DO NOT use Gorilla Glue. This stuff expands as it cures and unless you can clamp it well it will leave an ugly seam. Liquid nails would be my choice and brace it well with a piece of 2X4 flat on the fake diamond plate and another piece wedged in between frame, propane tank mount, or whatever is available. Maybe even bracing against tow vehicle bumper and CAREFULLY backinng up until brace is TIGHT against panel.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
