Old 05-14-2011, 04:02 PM   #1
Send a message via Skype™ to scubieman
How to level travel trailer on steep hill?
I was wondering how everyone levels on steep hill. For example if you backed your RV in it is so bad side to side level that your one tires maybe about off the ground to get it level.
Does anyone use a remote level ? So you can adjust each jack and look at level?
Any help is awesome. I do know how to level and probably get by but I figured anything to make levelling more of a quick task to get to the adult beverages.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 05-14-2011, 04:19 PM   #2
backin15's Avatar
Do not use the stabalizer jacks to level - they are just to stabalize the unit as the name implies. They are not designed to support the weight and will fail if too much weight is put on them and it could also damage the frame. Instead carry some leveling blocks. You can use wooden blocks or buy plastic blocks. The plastic ones are lighweight and lock together. Just stack them up and back the tires onto them. When level drop the stabalizers. If you have the torsion flez suspension you may also want to be careful to make sure both axels are supporting the load equally. The leaf spring style has a built in equalizer so it is not as important. I use the stick on bubble levels for quick reference.
Also - chock the wheels so the trailer can't wander away when you unhook!
backin15 is offline   Reply With Quote
Old 05-14-2011, 04:20 PM   #3
You can put blocks of wood under the wells and then you can use the jacks to level the camper with the stabilizing jacks
Matthews1 is offline   Reply With Quote
Old 05-14-2011, 04:32 PM   #4
I did not know if there is any other tricks for it. Cause I know I tried these methods with my dads RV but I had to back up check level side to side , if not level pull forward and add more wood then back up. I did not know if there is a easier method.
Old 05-14-2011, 06:04 PM   #5
I use a long ramp about 6' long and make a gradual slope then just back it up the ramp till level, chock wheels, unhook, level front to rear and stabilize. YMMV
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 05-14-2011, 07:15 PM   #6
cheese53073's Avatar
This style level has inch markings on it. back into your site, read the level, pul forward, place the correct thickness of risers down behind the wheel and back into place. side to side leveling is done.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 05-14-2011, 07:31 PM   #7
kalik282's Avatar
I use this Camco level...can be seen from the drivers seat, and graduated in 1" increments. Since it's a mercury level, the "ball" drops to the low side. Makes it very easy to know where to add the blocking.
Amazon.com: Camco 25563 RV AccuLevel: Automotive
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 05-14-2011, 07:35 PM   #8
Terier's Avatar
I may be off the mark but do you mean if it on the one inch mark you will need to 1 inch some sort of riser? Do uyou use use a level on all sides of the trailer?
Old 05-14-2011, 10:49 PM   #9
yes
one on the front for side to side leveling
another goes on 1 side for front to back leveling with your tounge jack
Rockwood 8293RKSS
