Old 04-12-2011, 12:21 PM   #1
How to retrack slide when no power
I didn't find a thread for this particular problem so here goes. Last year I purchased a used Cherokee 27 L (my first camper). I enjoyed many outings with it with no problems. So far I haven't had a problem with the slide out. But one thing that crossed my mind is what do you do when you have power failure. Is there a spot some where a manual crank could be use? If so where do I find this spot to crank it in manually? I surely don't want to crawl underneath if I don't have to. I have been using a cordless drill to lower and raise my corner stabilizing jacks. Can this drill be used for this too? Happy camping everyone!!!
kjoh75 is offline   Reply With Quote
Old 04-12-2011, 06:50 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
It's been so many years since I've had to crank in a slide that I can't remember the fine details. The trailer should have come with a cranking handle, the end of which is inserted near the slide motor. Maybe someone else can be more specific.
Edited: This should help. http://www.eco-rv.com/scripts/pdfretail/get.php?id=366
dimurrrw is offline   Reply With Quote
Old 04-13-2011, 04:12 PM   #3
Droidrt's Avatar
I too am the owner of a 2011 grey wolf 28 bh. although I hope I don't ever have a problem, the thought has occurred to me. my dealers showed me where the crank and access point were. I was wondering if it would cause a problem if I extended and retracted it manually a couple times, just to get the hang of it in case I ever need to use it?
Droidrt is offline   Reply With Quote
Old 04-13-2011, 05:02 PM   #4
Send a message via Skype™ to scubieman
You can crank in as much as you want. Its takes long time.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 04-15-2011, 12:15 AM   #5
Careto post where? I have a 2010 28bh and I don't remember it on my walk thru, but that was a year and a half ago.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 04-15-2011, 06:34 AM   #6
Big Dawg's Avatar
I actually asked during my walk through, no one knew how to do it. I have to do some reading on this subject. I hope I never have to do it either...lol
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 04-15-2011, 10:07 AM   #7
Droidrt's Avatar
I thought I remembered it being in the center of slide under the trailer, but when I looked this morning, that was the low point drain. Now I HAVE to find ours and try it out this weekend. If I think of it, I'll try to take some pics.
Old 04-19-2011, 10:14 PM   #8
Droidrt's Avatar
Ok, I looked but with very little success. I found where it is but couldn't figure out where the crank handle would go if I needed to manual crank slide. Asked dealer flat out, I was told on the 28BH that it is under the couch on front end of trailer. It is actually under the platform that the couch sits on. He said it takes some work to get to it. Not sure if this is true or if he told me that so I wouldn't tear apart my slide to find the motor. Seems Forest River would make this more accessible though.
Old 04-19-2011, 11:40 PM   #9
BOBFIDY's Avatar
On our Salem with 2 slides on driver side .....the slots for putting the manual crank are on the passenger side about in the centerline of the slides.
Hope that might help some.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 04-20-2011, 05:08 AM   #10
acadianbob's Avatar
Hook up the umbilical to your tow vehicle and start it. . . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
