Old 03-28-2016, 04:28 PM   #11
Georgia Frog Rally 2018
aceinspp's Avatar
All the manual awnings I had, had the pull strap at the middle of the awning. Once you release the turn nobs on each side of awning arms then go to the right side of awning as facing it. Use the awning rod to move the lever at the top down ward. Now you should be able to hook the strap with rod and pull down. Once down you can now extend the awning arms one each side and slide till they lock in place. From there its just a matter of adjusting for height and locking in place with turn nobs. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 03-28-2016, 04:46 PM   #12
Most of the Awning straps were in a Drawer with the New Filter cartridge! Youroo!!
Old 03-28-2016, 05:03 PM   #13
Oaklevel's Avatar
Just be careful don't try to stop the awning from rolling up by putting your arm in the awning arm. I had to rescue a neighbor on the next camp site last summer that somehow got his arm stuck in the awning arm he was in great pain till I released the tension...........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-28-2016, 05:19 PM   #14
WolfWhistle's Avatar
Originally Posted by youroo View Post
I really like the part "Don't let it push your ladder over"! Youroo!!
X2... Get help until you are confortable doing it. When I had a manual awning, I kept the strap nearer the end with the release switch. You have to be holding tightly on the strap before releasing the switch as you found out. You also need to be sure you stow it correctly before hitting the highway. But don't you retrieve the strap using a ladder by yourself!
WW
awning
