Old 01-23-2019, 11:22 AM   #1
Ice Maker / Refrig Hatch
I have a 2018 Grey Wolf DBH that came with an ice maker and small refrigerator which is located next to the main entrance door. I want to use that space a bit differently, but there a large metal "tray' I need to remove. First problem is it's crimping the heater duct running behind it and 2nd I just won't need it. I have all the visible screws out but it will not budge. Thinking it may be screwed from below, but I can't look under there due to the underside cover. Looking to see if anyone knows how I can remove this metal tray. Thanks.
martinrw1 is offline   Reply With Quote
Old 02-04-2019, 04:00 PM   #2
Terry Luther's Avatar
metal tray
can't help you . I have a 2018 cherokee with the ice maker and small frig also but no metal tray. mine just were screwed to the plywood floor.
If you haven't used the ice maker yet you might be in for a surprise!
In order to drain the ice maker after use you have to unscrew it and take it out because the drain is on the bottom.
Old Hunter
Retired from the USAF in 1979,
Build porch swings to stay busy when not hunting.
Cherokee 264 DBH
Ram 1500 double cab TV.
Terry Luther is offline   Reply With Quote
Old 02-04-2019, 06:38 PM   #3
Wish mine didn't. And yes, I have experienced the ice maker drain problem. I will be doing something to resolve that problem soon. Love the RV otherwise.
