Old 07-28-2018, 10:25 AM   #1
Improvements to my new Wolf Pup 16FQ
We are getting ready for our maiden voyage with our Wolf Pup 16FQ next weekend.
Here is what I have added/improved so far.
Replaced crank jack with power jack
Added Camco bug screens
Added gas gauge to propane tank
Added Camco propane tank cover
Put lock on hitch
Added a 3” cool foam topper to the queen bed (it is hard!!!)
Put under mattress hanging storage pockets on each side
Added 6 tap/remote LED lights throughout
Installed paper towel holder and TP holder
Put stick on hooks in several areas
Installed a Bluetooth remote in/out thermometer
Replaced shower head with Oxygenics Fury
Installed a 19” TV
Future improvements will include;
Better tires
Adding a second 20lb propane tank
Solar panels or generator (maybe both)
I guess after a trip or two we will find some other things that need improving.
jcgso is offline   Reply With Quote
Old 07-29-2018, 08:06 AM   #2
SeaDog's Avatar
Wow all that and you haven't even taken it out. Just think how long the list will be when you actually use the rig! LOL
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-29-2018, 08:10 AM   #3
Looks like you've been very busy getting your Wolf Pup modded to fit your needs. Enjoy your maiden voyage next weekend!
Old 07-29-2018, 09:42 AM   #4
Thanks! We had a month to get it ready and some $ to play with. Most of what I did was based on reading these forums. Very appreciative of all the great info here.
Old 07-29-2018, 09:59 AM   #5
rsdata's Avatar
I would certainly add a TPMS to your list of must have's
TST 507 is great
“Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 07-29-2018, 01:17 PM   #6
Here's another
We have a 16FQ also. Got tired of lifting up the bed to get access to the storage area. Removed the front panel and made two hinged doors. I'll see if I can attach a picture. Also added a medicine cabinet in the bathroom.
ID:	181640   Click image for larger version
remach67 is offline   Reply With Quote
Old 07-29-2018, 01:45 PM   #7
Really like the doors under the bed. I know my wife has a hard time lifting the bed.
Old 07-29-2018, 03:13 PM   #8
Also got 2 storage bins that fit right in.
Old 09-08-2018, 04:48 PM   #9
cherokeewolf's Avatar
You certainly have been busy!!! Hope all the mods serve you well and after the trip you will find more to make your unit better!!
cherokeewolf is offline   Reply With Quote
Old 11-16-2018, 05:21 PM   #10
Mad Cow's Avatar
In talks with dealer about a new 16FQ. Part of deal is to yank out the 6 cu fridge and replace with a Dometic 6 cu AC/DC compressor fridge. Also a Fantastic fan in bathroom.
Mad Cow is offline   Reply With Quote
Old 11-20-2018, 07:49 PM   #11
2thdr's Avatar
Can you give a link for the Bluetooth thermometer? Thanks.
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2014 CRF250L
2017 FZ-09
2thdr is offline   Reply With Quote
Old 11-25-2018, 11:31 PM   #12
https://www.amazon.com/ThermoPro-TP6...3206632&sr=1-1
Works great.
Old 11-26-2018, 10:49 AM   #13
Did you come up with an easy bolt on dual tank platform?
I keep thinking going to a 30# tank would be easiest for me. I think a 40# would be too tippy when using the current tank holder.
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
2018 16 days camped, 2019 9 days so far.
Boomerweps is offline   Reply With Quote
Old 11-26-2018, 10:58 AM   #14
I have not gotten around to the extra tank yet. I thought about a 30, but I don't think the cover I bought would fit, but it would work with two 20s.
My next upgrades will be a TPMS and two 6 volt deep cycle batteries.
Old 04-17-2019, 12:04 AM   #15
How did you attach medicine cabinet to back wall? I want to add that, but am afraid screws will go through wall!
AZRVW is offline   Reply With Quote
Old 09-08-2019, 12:27 PM   #16
Interested to know this as well
Nova 404 is offline   Reply With Quote
Old 09-08-2019, 03:21 PM   #17
Used a stud finder and made appropriate holes in cabinet
Old 09-08-2019, 07:14 PM   #18
https://72land-n-sea.blogspot.com/20...d-storage.html
jeffnick is offline   Reply With Quote
Old 09-08-2019, 07:30 PM   #19
A two bottle base is not that hard to install on the Pup...no welding.
Old 09-08-2019, 07:50 PM   #20
Put lock on hitch
Installed a 19” TV
Better tires
Here's something you'll eventually think about.
https://72land-n-sea.blogspot.com/20...your-head.html
I bolted on a tray for my Honda 2000i generator at the tongue. You could use it for another battery - Why wouldn't you just put on another 12?
I updated to a bigger (remote start) generator and moved it to the back bumper after removing the swing down carrier.
https://72land-n-sea.blogspot.com/20...generator.html
When you start thinking about better tires you might consider 15" rims. I run 15" car tires on my Pup.
wolf pup
