Old 06-06-2016, 06:49 AM   #1
Led awning lights
The outside led lights on our 2014 tt have more lights out than on. Has anyone replaced theirs? How easy is the task. Any tips from the DIY folks.
Pirateman98 is offline   Reply With Quote
Old 06-11-2016, 02:56 PM   #2
Steelframer's Avatar
Not very difficult. What you need is led lights (Amazon), a Phillips screwdriver, plastic putty knife, goof off, two 18 gauge solder less wire connectors (any home improvement store), and silicon. Remove old led strip, then remove screw holding black plastic cover over entry door, under the awning where the wiring goes into trailer, cut the wires finish removing LEDs, scrape all the leftover adhesive off of trailer and use goof off to finish adhesive removal, use solder less connectors to join new LEDs to factory wires under the black cover, install new LEDs, silicon under the black cover, replace screw and your done.
TT-2015 Cherokee 274dbh TV-2011 Ram 3500 Longhorn Limited
Steelframer is offline   Reply With Quote
awning, led, light
