Old 04-04-2013, 06:47 PM   #1
LED strip lighting
Has anyone wired up LED strip lighting up to 12v DC instead of buying a AC to DC power supply? I was planning of running it off the battery and installing a in line 6 amp fuse to protect the lighting and a switch.
240sundeck is offline   Reply With Quote
Old 04-04-2013, 06:51 PM   #2
Owner/Operator
RodeoGeorge's Avatar
Most people are using the RV 12V system for their LED Strip Lights.
Check out this thread, which will answer just about all your questions.
My solution to awning lights
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-04-2013, 07:18 PM   #3
Fulltime family RVer
And questions you never knew you had not probably wanted to have! LOL
Old 04-04-2013, 07:19 PM   #4
Herk7769's Avatar
Using a 120 VAC transformer to make 12 volts in a 12 volt trailer seems counter productive and will limit the LEDs use to shore power campgrounds (without an inverter).
HAM CALLSIGN - KC3FFW
Old 04-04-2013, 08:20 PM   #5
LKicklight's Avatar
Wiring
Probably right on that, but sure beats hacking into the wiring on the RV..the only thing I've got close enough is the outside light...will try it with the converter for now, can always go to 12V..thanks
LKicklight is offline   Reply With Quote
