Old 09-28-2018, 07:41 AM   #1
Longitude power awning not working
Ok I go to my site and there is tree close so I opened my awning and everything was fine (awning wise) I retracted it to move the trailer back a little to clear the tree. I set up the trailer (everything is level) went to extend my awning and I get nothing. Checked the fuse and it's fine bur I replaced it anyways and still nothing. The only thing in the downloadable manual is emergency retracting it. Can anyone help?
kinma13 is offline   Reply With Quote
Old 09-28-2018, 09:53 AM   #2
K2Kevin's Avatar
Battery charge, power hookups? Iím sure you checked, just saying... start with the small stuff.
K2Kevin is offline   Reply With Quote
Old 09-28-2018, 11:28 AM   #3
That's funny that's the same thing I asked and triple checked. I even waited till this morning and checked again thinking maybe it was the battery but nothing. Had a freind reach up at the motor and pull a little while I was hitting the switch and it started working so maybe it just rolled up to tight.
Old 09-28-2018, 11:31 AM   #4
K2Kevin's Avatar
Strange, you didnít even hear a motor sound when trying to extend.
Old 09-28-2018, 11:52 AM   #5
rracer5's Avatar
Sounds like there may be a "dead spot" in the awning motor. Your friend giving it a little "tug" must have gotten it just past the dead spot. That's probably one of those things that may happen periodically when the motor stops on the dead spot or.......it may never happen again.
2014 Sanibel 3250
rracer5 is online now   Reply With Quote
Old 09-28-2018, 01:19 PM   #6
Yeah was thinking the same thing. Kinda like the old starters that you had to crawl under the car and tap with a hammer.
Old 09-28-2018, 01:22 PM   #7
rracer5's Avatar
If that fails.........get a bigger hammer!
2014 Sanibel 3250
awning, power
