I'm getting ready to winterize my 2017 26dbh and was curious to know where the low point drains are on my trailer. I know where the freshwater drain is at.
Thank you.
Look under the trailer... should find a red and blue hose(s) with caps (normally Black). Not sure exactly where on your model.
Thank you.
I don't know where your LPDs are located but Find and set your Water Heater bypass valves BEFORE using your LPDs! This will keep "White Crud" from going Downstream in your system! Youroo!!
Good tip!
Retired Navy
2016 Flagstaff 26 FKWS
Both low point, WT drain and overflow tubes are white on the lite, caps are black.
LPD on street side in front of the front axle.
