Old 10-18-2018, 11:14 AM   #1
Low Point Drains 2018 Cherokee Limited 274dbh
First winter with a travel trailer. Can anyone help me find the location of my low point drains on a 2018 Cherokee Limited 274dbh trailer? Just graduated this spring from a pop up.
3DogWonderer is offline   Reply With Quote
Old 10-18-2018, 04:18 PM   #2
I have a 2017 and they are on the side with doors. There should be a sticker between the back wheel and the back door.
Bedlinedf250 is offline   Reply With Quote
Old 10-18-2018, 04:47 PM   #3
cavie's Avatar
Underneath the trailer. Red and Blue pipes sticking down. both have valves. If no valves, they are inside directly above the pipes.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 10-21-2018, 08:05 PM   #4
Mine are located under the cabinet for the outside fridge. As stated, should be a red line and blue line coming down.
Bsens07 is offline   Reply With Quote
Old 10-21-2018, 08:44 PM   #5
might have to crawl under and look for them. On my 2019 they are below the outside fridge, basically under the sink area. Mine were tucked up into the frame.
I camp to burn off the CRAZY!
Somewhere there is a Tiki Bar and a Jimmy Buffett song that needs me...
2019 Cherokee 274DBH
DonD is offline   Reply With Quote
Old 10-22-2018, 06:18 PM   #6
Success
Thanks to all who responded. I really appreciate the help. I found mine just underneath and to the left of the outside fridge. Thanks again!
cherokee, drain
