Old 07-19-2015, 08:13 PM   #1
slaslo's Avatar
Main breaker keeps blowing in 26DBH Grey Wolf
Any advice on how to trouble shoot why main beaker is blowing when coffee pot and AC are the only things running. Does a coffee pot need more than a 15 amp circuit? The coffee pot is a Bunn.
slaslo is offline   Reply With Quote
Old 07-19-2015, 08:19 PM   #2
wmtire's Avatar
It's all about total amps. If you are on a 30 amp main breaker, then you need to limit your self to 30 amps.
You may think that is the only two things...but is the fridge using AC 120 volt, how about the water heater, and how many 12 volt things (lights, pumps, fans, etc are you using. The 12 volt things are powered by your converter which converts 120 volt AC to 12 volt DC. The more DC things you are using, the more AC amps the converter is using.
There should be a label on the bottom of the coffee pot that tells amps or wattage. You can convert wattage to amps by this formula
watts = voltage X amps
Ex: 1440 watts =120 volts X 12 amps
More good reading:
http://rvservices.koa.com/rvinformat...lectricity.asp
http://rvservices.koa.com/rvinformat...d-amp-draw.asp
Hopefully, it's just something as simple as overloading the circuit which you can easily correct by turning things off, but it could be something else.
Can you turn the coffee pot off, and everything else running is good to go?
If so, then can you turn off the air conditioner, and everything else is good with the coffee pot going?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-19-2015, 10:09 PM   #3
slaslo's Avatar
Thanks so much, I was thinking I was doing something wrong by turning of the microwave breaker when running AC and coffee pot etc.
it makes perfect sense what you outlined. Thanks it really helped.
It's a little frustrating to turn things off... But.. I totally understand and will do so to keep from tripping breakers.
Best,
Scott
breaker, grey wolf
