Old 06-11-2012, 07:37 PM   #1
Manual crank for electric stabilizers?
Is there a place to operate a crank or something in case there is no electric for the stablilizers? We went out this weekend, forgot to put the remote back in the camper Luckily, we were only 45 min from home.
Awning and slide can be operated by the panel, but we couldn't find any place to manually lower the stabilizers.
2012 Grey Wolf 27BHKS
stitchinsue is offline   Reply With Quote
Old 06-11-2012, 07:39 PM   #2
TURBS's Avatar
What kind of stabilizers?
There is always a manual option.
Dealer should have showed u this.
Old 06-11-2012, 08:59 PM   #3
Twisty's Avatar
I was told to remove the motor and use a wrench on the exposed shaft.
I haven't pulled a motor yet - guess I should to see what fits...
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-15-2012, 02:00 PM   #4
BigTJohn's Avatar
On the PORT side of the TT there is a shaft for the Electric Stabilizers. A cross pin should be seen and that is the connection point for the manual crank handle. You should not have to remove the motor, on the STBD side for anything.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 06-15-2012, 02:23 PM   #5
Iggy's Avatar
Is this what you have?
See attachment and last page for manual use.
File Type: pdf om-rear-electric-stabilizer-jack-web21.pdf (423.9 KB, 211 views)
Iggy is online now   Reply With Quote
Old 06-15-2012, 07:25 PM   #6
Twisty's Avatar
Thank you, John!
Now I get to make an adapter for my cordless drill. I didn't get a handle and wouldn't carry it anyway.
2012 Surveyor SV264
NW Oregon
Old 06-15-2012, 08:12 PM   #7
FreedomTracker's Avatar
I don't have electric landing gear, but tired of manually cranking and wanted an electric drill I could keep in the TT.
Found a cheap 18v cordless drill w/ light & charger at HF on sale for $19.99 this week.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-15-2012, 10:09 PM   #8
Thank you for that pdf! I do not have that paper. I'm pretty sure those are the stabilizers.
