Old 10-22-2016, 10:41 PM   #1
Mounting Bedroom TV
I have a 2017 Grey Wolf 26dbh. I see it labeled on the bedroom ceiling as being a TV backer but cannot find information how to properly mount a TV. Has anyone successfully installed a TV in the bedroom and how did you do it? Thanks in advance for the help!
Flyguyjp1 is offline   Reply With Quote
Old 10-23-2016, 07:13 AM   #2
I have the same question. Also what's the largest TV size for the mount that's provided for the outside.
L129 is offline   Reply With Quote
Old 10-23-2016, 07:49 AM   #3
I've not tried to mount a TV in the bedroom (I dont trust the ceiling) but we've found the largest TV that fits comfortably on the mount is a 32". You might be able to go larger outside, but anything bigger than a 32" will give you fits trying to slide it on the mount in the living area.
Moellerdan is offline   Reply With Quote
Old 10-23-2016, 07:57 AM   #4
http://www.forestriverforums.com/forums/f24/what-size-tv-do-you-have-on-your-26dbh-mount-95003-3.html
Here is a thread with a picture of my set up. Post #26. There are a few threads here in the Cherokee forum on this topic.
Old 10-23-2016, 08:52 AM   #5
We have a 32" in the main living area that fits perfect. I am definitely nervous to mount any sort of weight to the bedroom ceiling.
Old 10-23-2016, 09:18 AM   #6
What brand tv? 32" don't look like they have the correct hole pattern to match that mount?
Old 10-23-2016, 09:23 AM   #7
We have a Vizio LED. Unfortunately I don't know the model number off hand and the trailer is parked in storage.
Old 10-23-2016, 10:19 AM   #8
I mounted a 32" in the living room also. It's a insignia brand from Best Buy. Was under $100 dollars on sale. Is 9lbs, fits in mount perfect. I agree any bigger would have issues sliding into mount. Plus it's just the right size and weight to move outside when needed. I just use a tablet if watching something in bedroom Click image for larger version
Name:	ImageUploadedByForest River Forums1477235941.222003.jpg
2017 forest river Cherokee limited 274dbh
Tow vehicle 2011 Toyota Tundra crewmax 5.7l v8. 4x4
kfcflores is offline   Reply With Quote
Old 10-23-2016, 12:24 PM   #9
x2. I also have a Vizio. Purchased at Best Buy.
Old 10-23-2016, 10:08 PM   #10
jsharrimangraywolf's Avatar
TV's
In living area 40" Samsung. In bedroom 24" RCA with built in DVD player which I transfer to outside mount. 32" in bedroom was a difficult fit. Bedroom mount is to backside of living area faux rock, not to ceiling. The doors can still remain open with stock width of latches. I used the stock mount for bedroom tv with that being attached to an extended swivel mount. The living area mount is a heavy duty swing mount to a certain degrees so it can be viewed from the sofa or eating table. It is sturdy enough to be left on for travel. The bedroom tv I take off during travel.
Name:	RV tv Living.JPG
ID:	123724   Click image for larger version
Name:	RV tv Master.JPG
2016 Gray Wolf 26DBH
2001 F250 Super Duty Crew
2014 Chevy Suburban
jsharrimangraywolf is offline   Reply With Quote
bed, mount, roo
