09-20-2018, 09:55 AM
#81
Originally Posted by K2Kevin
That’s correct, it’s the receptacle for the water heater. I keep it unplugged when the heater is in by pass and have no plans to use it.
Since this is under the bed, I can barely hear anything when it’s running.
Oh and that blue thing on the floor in main storage area to right, is just an old queen size air mattress. Helps things from sliding around.
Finally checked out my pump & heater area for details. Looks like I missed that power outlet, I have one there, too. My water pump is already in the place you moved yours to. I will reroute my external shower hoses that are twisted to be almost intentionally taking up the maximum space in there.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
09-20-2018, 11:58 AM
#82
You have an external shower? Did you add that to the Wolfpup? I have been thinking about adding that recently, looks like it would be a real easy install.
09-20-2018, 12:36 PM
#83
Mine is a 2019. The external shower was factory. Seems like just a rectangular hole through the walls. T fittings in the PEX tubes with screw fittings that accept a standard faucet hose, screw fittings on both ends. After I blow air through the system for winterizing. I will disconnect and reroute the one twisted up hose up nearer the pump.
09-20-2018, 03:42 PM
#84
I have a 2017... I've wanted to add the outdoor "shower" since purchase, thats exactly where I planned to put it. I also saw that the 2019 16BHS has a larger fridge, but you loose a little storage. Id rather the larger fridge/freezer! Otherwise, I've been very happy with the wolf pup!
09-20-2018, 07:24 PM
#85
Think you missed it by a year. I was sold on the 16BHS based on a detailed Utube review for the 2018 model. Only difference 2018 to 2019 was the big refrigerator which also lost some counter space and the tall thin storage closet. I was set to buy the 2018 when the dealer I was dealing with said they got the 2019 model MID-APRIL! I did see a recent Utube 2019 review that shows all the back side windows as the escape tilt out type. I'd have preferred that for in the rain but my bunk and dinette windows are sliders, just the master bed has the tilt out window.
It shouldn't be too hard to add a shower box to your camper.
This weekend I plan to add a separate 15/20Amp inlet to the TT and run the wire up inside the wall near the table if I can, otherwise the outlet will be placed on the back bench's kick panel easy enough. This is to power heating element devices separate from the main 30Amp system, like space heater, coffee maker, or toaster. Add one of those to the AC & fridge and it could be bad news. And forget about the microwave I always shut off the AC when microwaving.
09-24-2018, 11:00 AM
#86
K2Kevin,
Camping world has the outside shower kit on sale for about $45, in black & white.
09-24-2018, 11:58 AM
#87
K2Kevin,
THX. Im more partial to ordering on amazon. Ive found a few, not ready to do that install under next spring.
10-02-2018, 11:32 PM
#88
Hi,
For Mod # 7 did you purchase or build your own custom cabinet and mirror? I like it!
