Old 03-17-2017, 06:40 PM   #1
Mystery switch
I just bought a 2017 wolf pup 18to . There are 3 switches just inside the door on the left hand side of the outer upper cabinet . One switch is for my slide , one for my exterior porch light / scare light but the third switch has me stumped ??? Any help would be appreciated ! I have pulled the switch and it is hooked up to something !
Thompson239 is offline   Reply With Quote
Old 03-17-2017, 06:42 PM   #2
Left Coast
Turn an overhead light on, then see if switch will turn it off
Old 03-17-2017, 06:59 PM   #3
I did that and no effect ! It's about to drive me crazy!
Old 03-17-2017, 07:03 PM   #4
Who Dares, Wins
doc73's Avatar
Do you have ground lighting or tank heaters? Could it also be for the hotwater heater.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 03-17-2017, 07:41 PM   #5
Blackrock's Avatar
Check for a light at your steps. Hard to see in the daylight.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 03-17-2017, 07:43 PM   #6
bikendan's Avatar
Pics are always helpful
Equalizer WDH
Old 03-17-2017, 07:52 PM   #7
I figured it out ! It's a motion light ! Turned it on tonight and went walking around the camper and it came on as I passed it ! Thanks for the help guys !!
Old 03-20-2017, 02:13 PM   #8
thanks for that! That switch in our 18to has been driving me crazy too!
mikenac is offline   Reply With Quote
Old 03-20-2017, 02:39 PM   #9
I'm glad I wasn't the only one ! It's labeled now ! Tell me this ! Does your rurrion DVD play play through your tv ? I get the audio through my stereo speakers but no picture on tv
Old 03-20-2017, 05:48 PM   #10
dmchapman's Avatar
Look at the menu on the tv set.On the remote you might have a source button. If not use menu. There should be an option for source. On mine it is HDMI for the DVD player.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 03-20-2017, 05:57 PM   #11
Man... these dealers must not be showing new customers anything!
Shame on them.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 03-20-2017, 05:59 PM   #12
I tried that but it changes the input and I'm useing only the coax that is wired in the camper . The salesman said all I had to do was turn off the power to the antenna and the built in DVD player would play through the coax but it not having any luck
Old 03-20-2017, 09:04 PM   #13
Yes it does play through my tv. Input set to avi and it works like a charm
Old 03-20-2017, 09:05 PM   #14
I don't think it works that way. Do you not have the red/yellow/white avi plugs?
Old 03-21-2017, 05:32 AM   #15
Not pre wired in the camper just the coax .
Old 03-21-2017, 07:45 AM   #16
honestly im really not sure how that would work. if they put the dvd player in it i imagine it should work somehow. did you try different channels on the tv like 3 or 4?
Old 03-21-2017, 08:13 AM   #17
I did but I will definitely try again . If it doesn't work I will have my work cut out for me tring to fish the wire back through the walls and things
Old 03-21-2017, 09:40 AM   #18
ya that will not be fun. my av connectors are in the roof right next to my coax outlet. i imagine if you pull the radio there will be unused connectors behind it that you need to hook to.
Old 03-23-2017, 08:09 AM   #19
Thank you, I also was wondering what that switch was. It will get labled now as motion detecter. I was looking for a battery disconnect switch on our 18to but haven't found one, does anyone know if they come with one or is that a dealer add on?? New to the site and travel trailers, always had a tent trailer
Swamprat54 is offline   Reply With Quote
Old 03-23-2017, 08:12 AM   #20
Left Coast
Alot of folks install their own, simple job....
switch
