Old 06-03-2019, 02:21 PM   #1
Need info to repair my electric jack
1st time out this year and my electric jack started acting up, working intermittently and then just quit working altogether. I used the manual jack for our trip and starting troubleshooting when I got home last night. I have power running up to the motor. There is a little sealed box that jumpers the incoming to outgoing wire. I have no power from the outgoing wire. So I believe that is the problem. The other issue is that the sticker on the front of the lift is completely sun faded so I can even research what make/model it is.
It has 1 switch for up/down at the bottom and a red switch for the side lights behind. Neither of the side lights work as well which makes sense if no power is getting past the jumper/relay/solenoid/whatever that is???
Thanks for the help in advance.
Vankonk is offline   Reply With Quote
Old 06-03-2019, 02:24 PM   #2
Pics
ID:	206313   Click image for larger version
ID:	206314   Click image for larger version
ID:	206315   Click image for larger version
Old 06-03-2019, 02:56 PM   #3
Yep! That would be your issue. Mine did the same. Removed the breaker and opened it up to find the contacts to be rusted. Bought one at me local auto parts store for less than $10. Simple fix!
Barmstrong77 is offline   Reply With Quote
Old 06-03-2019, 03:23 PM   #4
Thanks for the info.
So what is the part and what is it's purpose? I'm assuming since they went through the hassle of sealing it tight, it must be of some importance.
Old 06-03-2019, 09:01 PM   #5
It is a cheap resettable breaker. Made with bi-metallic contacts . When too much current flows thru the contacts they heat up and they’ll open and break the circuit therefore no more current flow. Once the contacts cool down they’ll close and allow current flow. The sealant/paint used was to seal the breaker but the manufacturer of the jack failed miserably! One the side of the breaker should be the rating for volts and amps. I used a 12vdc/20amps on mine.
Old 06-04-2019, 12:58 PM   #6
Self-resetting...
I would have called it a "self-resetting" breaker to distinguish from resettable breakers that are only resettable with manual intervention.
Larry
Larry-NC is offline   Reply With Quote
Old 06-04-2019, 01:02 PM   #7
Kasual Kamper
On a related note, do those gears need to be lubed periodically? Mine is working fine, but it sounds like it's straining sometimes (or is that just the nature of the beast?).
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is online now   Reply With Quote
Old 06-05-2019, 09:45 AM   #8
Thank you Barmstrong77 for the great info. So here is what I ordered.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I might have to use some caulk to seal it.
I did check the gears when I pulled it all apart and did not see any water penetration. I am going to grease them since I have it apart. Simple to do. Mine was only 4 screws to remove and inspect.
Old 06-05-2019, 09:49 AM   #9
RV There Yet?
IsleDog's Avatar
you can try using some type of silicone self fusing tape. Rescue tape is a brand name. works great, just cut it to remove. apply like electrical tape. completely water tight, gas proof, great stuff to keep in the tool box anyway.
https://www.amazon.com/Rescue-Tape-R...99950047&psc=1
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 06-05-2019, 09:57 AM   #10
Awesome. I will check it out.
electric, repair
