Old 05-21-2018, 10:58 PM   #1
New discovery about the factory rear rack
New personal discovery, that is.
I had thought the rear rack was attached to the bumper. It it NOT!
The hinge section top may rest on the top of the bumper a bit but it is actually clamped with bolts around the frame in front of the bumper.
So the clamped on hinge is bearing the major weight of the rack and not the bumper.
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 05-22-2018, 10:47 AM   #2
MillMitch's Avatar
Our Grey Wolf 23Mk is the same way. The 200# capacity cargo rack is mounted to the frame, and when it's down and the pins are in, sits slightly above the bumper.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 05-23-2018, 06:13 PM   #3
i would still be careful on 200 lbs max
bhirmiz is offline   Reply With Quote
Old 05-23-2018, 06:31 PM   #4
That's how most of those fold down racks are built. The bumper still supports the rack, but the rack doesn't create the torsional force that something clamped to the bumper would create.
2011 Traverse LT, 3.6L, FWD
Old 05-23-2018, 06:53 PM   #5
Flybob's Avatar
You are still adding a lot of weight to the manufactured beams of the frame. Between the weight and stress of the items moving around you are placing a lot of stress on the frame.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
cover, factory
