Old 04-26-2012, 08:10 AM   #1
cstover's Avatar
New to me 2010 Grey Wolf 28bh
Just picked up a 2010 28bh. It looked great when I looked at it and did my examination of it. Got it home and hooked up to shore power, started to get a sulfur smell. Walked around it and heard the battery boiling. Used the battery disconnect. Prior owner never kept the level up in it. Battery took over 1/2 gallon of water. Guess what, doesn't work anymore. I guess I need to get my fine tooth comb out and pms everything, even it if looks ok, just for my piece of mind.
Help me get a list together.
Chris
cstover is offline   Reply With Quote
Old 04-26-2012, 08:14 AM   #2
TURBS's Avatar
Time for a new battery for sure!
Old 04-26-2012, 08:19 AM   #3
TURBS's Avatar
Wheel bearings
Brakes
Magnets
tires
Lights
Anode rod
Water filter
Fresh grey and black tank clean and flush
Old 04-26-2012, 08:52 AM   #4
Big Dawg's Avatar
Welcome on the site, and congrats on your purchase. If you bought it from a dealer, you might check to see if they had a warranty on the battery.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 04-26-2012, 09:06 AM   #5
cstover's Avatar
It was a private party sale. The dates were not removed on the battery, but I can easily fix that for the prorated portion. $103 for the new battery. Not too shabby.
We upgraded from a 2005 Flagstaff 625D popup. We had bought it to see if my dw would like it and she did. So we just upgraded. Love it, but I need to go through it to trust it.
Old 04-26-2012, 09:19 AM   #6
TURBS's Avatar
Imo 103.00 is a little high!
Old 04-26-2012, 09:31 AM   #7
Herk7769's Avatar
Yep, Good series 24 Dual Purpose batteries in the 75 AH range should run about 75 to 80 bucks.
HOWEVER, your converter should not have boiled your battery. A shorted cell should have tripped your converter off line. That it stayed on and kept shorting into the battery needs to be investigated BEFORE you hook up a brand new battery for it to eat. Just my opinion.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-26-2012, 10:23 AM   #8
cstover's Avatar
Ok, I hooked up the multi meter without the charger on, battery read 4.58 volts, hooked it back up, it went up to 12.89 and then dropped slowly to 12.10. After a minute I cod hear the liquid bubbling and disconnected. What should I check? The wires are hooked up correctly and they were tight, there was no corrosion on the connections. The only thing was the low fluid level.
Old 04-26-2012, 10:48 AM   #9
Herk7769's Avatar
Not sure what converter you have, but this is the manual for the WFCO.
The troubleshooting section is at the back.
Home
This is their website and tech support may also help you.
File Type: pdf Manual - Power Distribution Center WF-8900 English.pdf (1.89 MB, 39 views)
Old 04-26-2012, 10:57 AM   #10
cstover's Avatar
8955 is what I have. I will go through that when i moor up tonight after this patrol.
Old 04-26-2012, 11:27 AM   #11
cstover's Avatar
I just read through the ts section and it was only looking at the no load voltage of 13.6. So we will see when i get home.
Old 04-26-2012, 06:00 PM   #12
cstover's Avatar
Just did test. A solid 13.60 from the converter. Put the new battery in and no problems yet. I am running the fridge and hot water heater to make sure they work. So far so good.
28bh
