Old 05-29-2013, 10:29 PM   #1
New to the travel trailer world, need advice
Just picked up our 2013 Cherokee 22bh and went camping this weekend! Had some issues. Noticed water dripping from the fresh water tank, about a drop every 10 seconds. Left front window leaks, water pump kicks on every now and then for about a second or two. Not sure if that is normal. I guess my main question is should I bring it in for repairs or wait till camping season is over? I have an appt on June 12 but tempted to cancel cause we can live with these issues. Anyways this a great forum! Have found so many answers to my many questions.
Emojo123 is offline   Reply With Quote
Old 05-29-2013, 10:42 PM   #2
It is normal for your water pump to kick on IF you are using water, however if it is constantly kicking on you may very well (most likely) have a leak in the system some where. You want that checked out.
If I had a window leaking, I would want it checked right away. Water leaks now can cause you problems farther down the road.
Can you see where your fresh water tank is leaking. Is it possible the drain valve is not completely closed.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 05-29-2013, 10:48 PM   #3
If everything inside & out water wise is turned (OFF) and the Pump cycles and water is dripping out of unit,(Take to Dealer NOW)! Youroo!!
Old 05-29-2013, 11:02 PM   #4
Not using water just kicks on by like its losing pressure. Looked around a little bit and found a leak at the fittings under the vanity and fixed that but still kicked on. Drain valve is closed, water is dripping onto axle. I'll bring it in and hope they don't have it to long. Thanks for the quick responses
