Old 11-01-2016, 02:36 PM   #21
Originally Posted by Xrrider View Post
Never used antifreeze in water lines. I blow air through entire system wit all faucets open and low point open.
2016 274 duh
2008 GMC 2500hd Duramax
Originally Posted by fanrgs View Post
That's what I do also. I just pour a little RV antifreeze in each P-trap, a cup or two in the black tank, and a tiny bit on the toilet flapper seal. I am still using the same gallon of antifreeze I bought two years ago. I also take out the anode, let the WH dry out, and then replace the anode.
Question regarding using air to blow out the lines. I have always used anti-freeze but I just did the air deal this weekend, but now I'm questioning the pump. I would guess there is water in the pump since we use our FW tank? We rarely have water hook-up. I am considering still using anti-freeze just so I can get some in the pump. (I still plan on putting some in the traps and toilet regardless) Any thoughts?
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 11-03-2016, 05:08 PM   #22
Drain fresh tank and all water lines, including inside and outside shower sprayers. Empty water filter housing, let filter dry, and replace housing. Blow out lines using screw-in adapter on city water fill. Unscrew pump filter screen, empty out water, and replace. Run pump for a very short time, check filter screen housing for water and empty if necessary. Repeat until no more water drops appear in screen housing. You should have no pump freezing problem after that.
"Retirement is the best job I ever had!"
2020 Winnebago Navion 24V Sprinter Class C
Sold in 2021: 2016 Rockwood Signature Ultra Lite 8244WS 5th Wheel
Sold in 2014: 2012 Rockwood Mini Lite 2109S
fanrgs is offline   Reply With Quote
Old 11-03-2016, 06:23 PM   #23
Some water may remain in the foot pedal toilet valve.
Henboy is offline   Reply With Quote
Old 11-03-2016, 06:31 PM   #24
AquaMan's Avatar
Don't forget your black tank flush lines, if so equipped. Blow the lines with air, no need to run antifreeze. Failure to do so will most likely end in a mess come spring when you decide to do a tank flush. It's not really the lines you have to be concerned with, but the anti-siphon valves.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
newbie, winter
