Old 10-12-2019, 07:06 AM   #1
Newbie switch question
I just purchased a 2014 wolf pup 16BH and have no clue what this switch is. Anyone know? The lady at the dealer said she thinks it's for the water heater, but didnt know much at all.
hann2723 is offline   Reply With Quote
Old 10-12-2019, 07:39 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. It could be the water heater switch or the potable water pump given the location. One way to tell is turn it on and listen for the pump to start or the water heater to fire. (make sure you have water in the heater)
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-12-2019, 07:41 AM   #3
Thank you! I do have a water pump that I found by the storage tank. I am going to see if it turns on
Old 10-12-2019, 07:46 AM   #4
SeaDog's Avatar
I forgot to mention make sure your propane is on to verify if it is the water heater switch or not.
Retired Navy
Old 10-14-2019, 07:33 AM   #5
K2Kevin's Avatar
Iíd say your 100% right, looks like itís the water heater switch. Iím not sure about the 2014, but the only switches are for water pump and water heater, donít think you have anything else on that unit.
K2Kevin is offline   Reply With Quote
Old 10-14-2019, 07:55 AM   #6
Yes it is for the water pump. Thank you for your help
Old 10-14-2019, 08:22 AM   #7
wmtire's Avatar
Glad you figured it out. Now do you know "if" and where your switch is to the water heater.
I say if, cause not all water heaters will have a switch, as some are pilot light models, thus no switch to turn on/off the direct spark ignition (DSI).
If you do have an inside switch to the DSI, there will usually also be a fault/reset lamp right near the switch button. This lamp will only go to switches that are for the DSI for the water heater.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 10-14-2019, 08:25 AM   #8
wmtire's Avatar
Since you stated you were a newbie, this thread may can help too:
New to RV's helpful hints
The thread in the link above about suburban water heaters electric switch, will explain the DSI and the fault lamps.
newbie
