Old 12-17-2014, 05:55 PM   #1
Rideandslide's Avatar
Nitrogen in Tires
Our new TT has Nitrogen filled tires, how are you suppose to top off the pressure ? Before every trip i always check and top of the tire pressure. Should i just go back to good old air ????
Jim
Rideandslide is offline   Reply With Quote
Old 12-17-2014, 05:58 PM   #2
Rrickim63's Avatar
If you have access to nitrogen, go for it. Otherwise regular old air will be just fine. It's 78 percent nitrogen anyway
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 12-17-2014, 06:23 PM   #3
B47
Jim
Do a search here about nitrogen filled tires and you'll find many comments,both pro and con.
I just added air after a hassle trying to find a nitrogen service place. Just add good old air - it has worked for many years.
Old 12-17-2014, 06:45 PM   #4
mattb's Avatar
I for one call BS on nitrogen, if you monitor your TPs as you should, it will make no difference.
2008 Roo 21SS
2003 GMC 1500HD 4X4 6.0 3:73 Diablo tuner
mattb is offline   Reply With Quote
Old 12-18-2014, 04:40 AM   #5
Many thanks guys, i will just get an water separator for my compressor and go with that. You would think they would market a compress nitrogen bottle for home use, like we are talking about !!!
Jim
Old 12-18-2014, 07:11 AM   #6
sail2liv's Avatar
I feel if tires come new with nitrogen that is a good thing....just add air and when you replace tires have the new one filled with nitrogen...or if you have a flat and are keeping the tire refill with nitrogen....course if you have flat when towing then you should replace both tires on the side the flat occurs.....good luck....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 12-18-2014, 07:32 AM   #7
MtnGuy's Avatar
I have run 78% nitrogen in my tires from the get-go.
Old 12-18-2014, 07:47 AM   #8
Flybob's Avatar
78% Nitrogen is easy to find at many locations.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-18-2014, 07:51 AM   #9
Rrickim63's Avatar
Mtnguy and flybob...too funny
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Old 12-18-2014, 08:02 AM   #10
Yep ! I totally agree, think my compressor in the shop produces that 78% stuff.
Jim
tire, tires
