Originally Posted by Glampster67
Hey Darrin, 2017 27DBS here, I think I already commented on another post of yours about the heat situation. The cool nights here in Tennessee and the cool nights in Ontario might be a "little" different to say the least but in the winter here, 20's and 30's I ran mine to see how it would heat and it did fine.......except for the bathroom....no heat in the bathroom so it was kind of cool in there. But there is a plug in there so you can plug in a small heater and probably be good.
I also am going to add another vent in the area under the stove where you can access the furnace and see there are unused knockouts on the furnace. I plan on knocking out the one right on the front there and adding a vent right on the wooden access panel right there to help distribute the heat throughout the camper.....
Just a precaution: That grill under your stove is the cold air return. You don't want to put a hot air vent too near to that or you'll just be short-circuiting your hot air back into the furnace. That's why the two vents you do have are run out to the sides as far as they could take them. Also, keep in mind that any air flow to your "new" vent will rob air flow from the existing vents.
Good luck.
2011 Traverse LT, 3.6L, FWD
