Old 06-30-2019, 10:33 AM   #1
No hot water
Am I still in bypass? I canít tell.
Sarjent is offline   Reply With Quote
Old 06-30-2019, 10:35 AM   #2
Trying to figure out how to post pictures from a phone.
Old 06-30-2019, 10:36 AM   #3
Old 06-30-2019, 10:45 AM   #4
The valve should be parallel with the pipes to be open so it seems you are still in bypass.
Glampster67 is offline   Reply With Quote
Old 06-30-2019, 10:48 AM   #5
No Hot Water
Looks like those are 3 way valves. Look at the top of the valve (use a mirror) and see the arrow indicators on the top of the valve handle. From you picture it looks like the by-pass is closed but hard to tell. Should look like 90 degree angle. If the valves are in the correct position there may be a switch on the outside box (where you can hear the gas) it may be hard to see, you will have to look around.
bzac1954 is offline   Reply With Quote
Old 06-30-2019, 10:54 AM   #6
nomad297's Avatar
Not knowing the orientation of the valves, it could be in bypass or it could be in non-bypass. Since you have no hot water with the valves in the positions shown, try turning the lever on both valves so the levers are pointing away from the white tube instead of towards the water heater. If they wonít turn to this position, they are where they are supposed to be for normal operation now and you have a problem other than how the water is flowing.
Bruce
Old 06-30-2019, 11:01 AM   #7
So apparently mine is set up different... here is a link to another post that looks like your setup...
http://www.forestriverforums.com/for....php?p=1803836
Old 06-30-2019, 11:19 AM   #8
Thanks. Mine was ok and set to summer. I turned on the propane and started to heat. Then I reset the electrical and it heated as well. Appreciate the quick replies
hot water, water
