Originally Posted by mcsquish
So we have up graded to a Wolf Pup 18TO from a pop-up and I'm ready to start making some modifications. My first additions\question is to add a towel hanger and a TV mount at the foot of the bed. My question is what do people use to mount items on the walls? I'm thinking if I use the hardware that came I the packaging I'll end up with screw end poking through the other side of the walls...
Thank you for any help.
Scott
There is 1-1/2" of stud space in the walls built with wood studs so you can use regular screws.
At the door there is a switch for your lights. These are 12v so are pretty safe. Unscrew the switch and pull out a bit and you will be able to see the wall framing and depth you have to work with. Also, open your cargo hatch and see how thick the walls are there.
