Old 05-09-2016, 06:56 AM   #1
Parking tt on sloped gravel driveway
Hi all, we have a small wolf pup travel trailer. At home we are parking it on a sloped gravel driveway. Do we need to level it when not in use? What method would you recommend to make sure it is parked safely. We have the tongue jack on some blocks of wood and lowered the rear leveling jacks onto wood boards, but it's not completely level. Also have logs behind the wheels (1 axle) but would like to find chocks that work on gravel. Any advice appreciated
franco928 is offline   Reply With Quote
Old 05-09-2016, 08:12 AM   #2
It really doesn't matter unless you want to use a propane reefer. They need to be fairly level in order to work since the flow is all by convection based on rising warm fluid and sinking cold fluid. If you aren't using the reefer don't worry as long as it is secure and the roof drains where you want it to.
2015 335DS
ScottBrownstein is offline   Reply With Quote
parking
