Old 01-30-2013, 12:44 PM   #11
Graduate Member
RoadTrip's Avatar
It's for traveling long distances measured by time, not miles.
First you go 88 miles per hour, make sure you have 1.21 gigawatts of power from your generator and that switch turns on the flux capacitor.
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-30-2013, 01:22 PM   #12
FloridaPhil's Avatar
Roadtrip is correct! The switch change optional with that model....its for time travel.
FloridaPhil is offline   Reply With Quote
Old 01-30-2013, 04:53 PM   #13
Stanleyg's Avatar
Could it be to turn on and off an outlet?
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 01-30-2013, 05:06 PM   #14
dezeldad's Avatar
I think stanleyg has it ... I'm betting it controls the outlet outside under your awning. I have that setup on mine.
dezeldad is offline   Reply With Quote
Old 01-30-2013, 08:34 PM   #15
This may be a silly suggestion, but have you pulled the switch out to see if there is actually anything wired to it? Switch your main breaker and battery disconnect off first. If there is wiring to it, maybe you can use a voltmeter to figure out which breaker or fuse feeds it, and the breaker or fuse may be labeled with the service.
Old 01-30-2013, 08:54 PM   #16
Could that be for the outside receptacle for example for awning lights??? We had a Cruiser with an outside receptacle close to the awning that was controlled from a switch like that one from inside the trailer.
Canada is offline   Reply With Quote
Old 01-30-2013, 09:56 PM   #17
DougP47's Avatar
maybe they wired the water heater to that. so you didn't need to step outside to turn on the 120v when you wanted hot water. Just a thought.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 02-08-2013, 08:16 AM   #18
It isn't for the water heater but I was messing with awning and there is a recp up high on the outside I am guessing for awning lights. I am going to check that when it stops raining.
signu127 is offline   Reply With Quote
Old 02-08-2013, 08:22 AM   #19
TURBS's Avatar
Most likely yes its for awning lights .
Ps there's most likely an on/off switch inside your camper for it as well.
Turbs
Old 02-09-2013, 09:50 AM   #20
dezeldad's Avatar
First trip to the dealer for warranty work I complained that there was a light switch in the kitchen that wasn't hooked-up to anything. That's when I learned that the switch was for the outlet under the awning for turning off/on the awning lights from inside.
