Old 05-08-2019, 12:54 PM   #1
Rain Water Running Down Side of Camper Causing Discoloration
Hi,
We have a 40' Cherokee Destination camper, 2016. Bought it last summer, used.
On the roof there is a small gap where the two long sections of 'lip' (not sure what the correct term is) come together, and water is running down the side of the camper there. It has discolored the siding, you can see where it has run down and created the discoloration in several spots.
Is it okay to seal that gap with silicone to stop the water from running down, or will that mess something up? Is it there for a reason? In each of the four corners of the roof there is a 'spout' that allows water to drain from the roof; I would think those are the only places where water SHOULD be draining from.
Any information would be appreciated. Thank you.
The Long Long Trailer is offline   Reply With Quote
Old 05-08-2019, 01:10 PM   #2
D W
D W's Avatar
There are gutters up there. Are you saying part of the gutter is missing?
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
1984 CHEV SCOTTSDALE K20 2GCGK24J0EXXXXXXX (Chevrolet Legends-Class of 2019)
D W is offline   Reply With Quote
Old 05-08-2019, 01:38 PM   #3
Mopar Guy
I have the same gap in the gutter, I sealed mine. no issues
Dave
2019 Grey Wolf 24JS
1990 D350 dually reg cab. 5x14 injectors, s362 SXE turbo. Lenny Fustini Built 727. 4200spring stage 5 pin
Cost4133 is offline   Reply With Quote
Old 05-08-2019, 01:43 PM   #4
Okay, thanks.
Old 05-09-2019, 02:31 PM   #5
CaptnJohn's Avatar
Originally Posted by The Long Long Trailer View Post
Hi,
Don't use silicon,,,,,,,,,,,,,,
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 05-09-2019, 02:43 PM   #6
rsdata's Avatar
I would look around in a hardware store for some piece of plastic that would bridge that gap, then use either glue or some non-sag caulk to keep it in place... there are many different cleaners marketed to clean "black spots" on trailer sides
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 05-09-2019, 11:43 PM   #7
Black streak remover at any RV outlet or internet. Or you can use Simple Green. I use Gel Gloss. Cleans and leaves a wax shine. Be careful with solvents around decals.
markb422 is offline   Reply With Quote
camper, water
