Old 03-08-2019, 12:20 PM   #1
Rapid Jack
I would like to buy the Andersen Rapid Jack in case I ever have a flat and need to raise the flat tire off the ground. I have read MANY complaints on a google search about experiences some have had that it will not lift the wheel high enough to get the job done. Before I spend money on something like this, I would like to hear from someone who actually owns a Cherokee Grey Wolf 26DJSE or 26BH that has used one of these and can tell me if it works or not.
PinTwister is offline   Reply With Quote
Old 03-08-2019, 03:01 PM   #2
mz_cummins's Avatar
No experience with it, I actually bought the knock off one but after reading how it can overload the one axle I decided not to use it and got a bottle jack
mz_cummins is offline   Reply With Quote
Old 03-08-2019, 03:14 PM   #3
Iwannacamp's Avatar
I am no expert. I am not looking for an argument. I have no degree in mechanical engineering, but I do have some mechanical and common sense. I cannot see how raising the "average towable RV" with an aid like that could damage the tire, suspension or components. I might see how it could damage the frame, but not the other stuff. It is a temporary situation as you are not driving on one axle etc... YMMV
FWIW I own an aid device and hope they give it away unused after I go to the happy hunting ground.
2017 Puma 297RLSS
Old 03-08-2019, 04:09 PM   #4
dieselguy's Avatar
I've not seen it used on your particular unit, but I do know they don't work well on torsion axles or some of the MORryde LRE suspensions. These suspensions have more travel that a standard leaf spring / equalizer setup and the Anderson wedge simply doesn't provide enough elevation.
dieselguy is offline   Reply With Quote
Old 03-08-2019, 04:20 PM   #5
Rapid Jack
My experiences with a 35 foot bumper pull. and a 40 foot fifth wheel
I have a traileraid and recently purchased the Anderson rapid JackóBoth devices are about the same level of effectiveness.
I have used these devices many times over the years to change tires. The question of whether or not it will lift the bad tire off the ground is a function of the ground surface/level/grade etc. It has lifted the bad tire on some occasions.
Most cases it gets the bad wheel 85 or 90% then I use a bottle for 3-4 pumps and I can change the wheel.
Ideal? Not reallyóbut it is fast and stable which is more than I can say for just a bottle jack alone.
Fast and stable is what I want while on the side of the highway when I have to change a wheel.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
