Old 07-10-2018, 01:06 PM   #1
Remove liner underneath 2016 Cherokee
The tub overflowed and soaked the insulation under the tub. I need to remove the liner so I can remove the wet insulation and replace with dry but I can't figure out how to get the liner out.
lseltz is offline   Reply With Quote
Old 07-13-2018, 04:19 PM   #2
I just removed all the insulation from mine due to an flooding because the bathroom sink was left on. You will be amazed at where the water all runs to. Your best bet is to cut access hatches in the fabric. I cut them so they are like a hinged door. The hinge being towards the front of the camper.
I'm starting the re-install of insulation tonight. I also purchased Scrim Shield Repair Tape from Amazon to patch the fabric after I'm done. I'm re-insulating the whole underbelly of mine due to my leak.
ID:	179447   Click image for larger version
ID:	179448   Click image for larger version
gadgetgeek is offline   Reply With Quote
cherokee
