Old 08-02-2015, 10:29 PM   #1
Removing medicine cabinet
We have a Forest River Cherokee. It has 2 large medicine cabinets in the bathroom. We would like to remove the one over the sink to enable us better access to the sink. We cannot find any screws in it at all. Has anyone ever removed one before? We have the 25 KS.
montanacherokee is offline   Reply With Quote
Old 08-03-2015, 04:46 PM   #2
Yes, not in that exact trailer but in others. If yours is like the others, your will need to remove the cabinet's inner panels to find the screws. You have to remove the top or bottom panels on every shelf. Also the top most panel and the bottom panel too. You may also need to remove both side panels too. Then you should find the square head screws securing it to the wall. Be careful the inner panels are usually stapled in place. They need to be carefully pried out at the edges. They will crack easily. It's not always an easy task but it can be done.
OneRoomShed Trailer Tech is offline   Reply With Quote
