Old 05-05-2016, 06:36 PM   #1
ak_camper's Avatar
Removing TV frame 2009 Grey Wolf 29BH
I need some advice how to remove small television frame. I purchased larger television that does not fit inside. I have spotted four screws inside vertical sides and 9 more on the top but loosing them does not allow frame to be removed. It looks like there is some hidden screws in the bottom but those can't be seen. Does anyone know how to get to them. I don't want to break the frame if I need it in the future. Thank you!
ak_camper is offline   Reply With Quote
Old 05-05-2016, 07:22 PM   #2
Face frame removal
The face frame of this cabinet is probably held on with pocket screws and wood glue.If you've removed all viSable screws and it's still tight , then it is glued in also.
It is going to be hard to get it off without destroying it. You can try slipping a thin puddy knife between the box and the face frame and prying in different locations.The whole frame (part above tv area )will need to be removed also. Is it possible to take the whole cabinet assembly off the wall? This way you can see all the screws .
Hope this helps and good luck.
Xrrider is offline   Reply With Quote
Old 05-05-2016, 09:03 PM   #3
Who Dares, Wins
doc73's Avatar
How about leaving it and mounting the TV to a telescoping mount.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
frame, grey wolf
