Old 04-08-2015, 09:59 PM   #1
Replacement tires
Totally new to this stuff... I purchased a 2013 Cherokee 264RL and have been advised to upgrade the tires from the current Load range C tires to a heavier load bearing tire... The only decent upgrades require going from a 205 75 r15 to a 225 75 r15. Any body have any suggestions and is it possible to put the 225 75 r 15 on the original rims ??
Oh, and any tire recommendations would be greatly appreciated...
Thanks in advance !
2013 Cherokee 264 RL
2013 F-150 Ecoboost
ccorrie is offline   Reply With Quote
Old 04-08-2015, 10:33 PM   #2
Dave_Monica's Avatar
Here's a link to Goodyear Marathon tires at Tirerack... http://www.tirerack.com/tires/tires....R6V2&tab=Sizes
The 225/75/R15 D should fit okay on your rims but can you fit the 1.2" larger diameter?
Dave
Old 04-15-2015, 09:27 AM   #3
Is the reason for the upgrade just to increase the load capacity in general or is there a concern with the C rated tires?
I have a Cherokee 28A and JUST bought 4 new tires (C Rated), should I have gone up a grade?
2013 Dodge Durango R/T (Hemi)
2006 Forest River Cherokee 28A
2007 Jeep Wrangler (Wife's)
bwt74 is offline   Reply With Quote
Old 04-15-2015, 09:55 AM   #4
Not really interested in increasing load capacity as the Cherokee 264RLS has very limited capacity for additional weight as it is, but more so as a protection against potential damage caused should a "Blow-Out" occur. Not that higher load rated tires do not "Blow-Out", any increase in the load capacity can't be a bad thing... The upgrade was recommended by friends who are full-timers....
Old 04-15-2015, 09:57 AM   #5
ok, thanks. I'll keep that in mind for next time, that makes sense.
Old 04-15-2015, 10:22 AM   #6
Forgot to add that from some of the postings I've read, "Blow-Out" damage can be pretty expensive... Far more than the cost of the tires...
replacement, tire, tires
