I have a sidewinder with four bolts on the top of the turret instead of the one castellated nut on the bottom the revolution has, but I believe the maintenance is similar. I believe you torque your turret nut to 80ftlbs, but verify in your install doc.
I take mine apart every one to two years and lubricate all bearing surfaces with lithium grease (I use Lucas Red N Tacky). This keeps it from squealing and I can rotate it by hand, but not easily.
If any of the bearings are damaged, contract Reese. They were great about sending me new bearings free of charge.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
