yes, there have been several threads about this recently. most likely the roller shades are made by a company called Irvine Blind and Shade in Elkhart Indiana. look at your shades for a label to confirm this. then you can buy replacement brackets from the company or through a local distributor. from your picture you will probably need to take the valance off in order to get the new brackets installed on the wall. then you have to put the valence back on. finally you need to lift the roller shades up and snap them into place in the new brackets. not a hard job but it is not easy to get to the pieces with the valance in the way. one other thing I learned (assuming they are from Irvine blind) is that there are a black and white adjustment knobs on one end of the shades. their website shows how to adjust these knobs so the blind retract properly.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
