Old 03-15-2018, 08:18 PM   #1
Shower head upgrade
Ive seen a lot of posts recommending an Oxygenics shower head. From my preliminary research it looks like it may be a brand or kind of shower head. Can anyone clarify or supply a recommended model that I can shop for to replace factory cheapy? Thanks.
Nights Camping:
2018 - 44
avigator is offline   Reply With Quote
Old 03-15-2018, 08:51 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Look for the 'Oxygenics BodySpa' on Amazon or eBay.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 03-15-2018, 10:27 PM   #3
Fulltime family RVer
Ive had both the Oxygenics Spa and the Fury.
The Spa seems to boost low pressure better than the Fury.
But the Fury has different spray patterns and nipples you can play with.
We use the Fury and we are a bunch of damned Wookiees.
Old 03-15-2018, 11:06 PM   #4
SeaDog's Avatar
I went from the stock shower head to the Oxygenics body spa and really like it.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-15-2018, 11:12 PM   #5
NMWildcat's Avatar
Oxygenics body spa seems to work much better for us than the other multi spray pattern models of Oxygenics. You can get them cheaper from Walmart/Amazon, the link is just the first one I found.
http://www.rvpartscountry.com/Oxygen...xoCwtcQAvD_BwE
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 03-16-2018, 11:40 AM   #6
I also added an adjustable pressure regulator at the same time as the Oxygenics shower head, and holy heck! It'll take your tattoos off at certain campgrounds!
Ok, maybe not that much, but it's quite impressive now.
freyguy is offline   Reply With Quote
Old 03-16-2018, 12:01 PM   #7
Make sure you get the one with the shutoff valve where the hose and head meet. You want to be able to turn it off (mostly) without touching the faucet settings while you soap up.
The one in the link in Post #5 has the in-line valve.
Some of the early ones did not come with the in-line valve.
2011 Traverse LT, 3.6L, FWD
show, shower, upgrade
