Old 05-31-2009, 08:47 PM   #1
Shower Leak
We have a 2008 27Q Cherokee and used the shower for the 1st time last summer. We noticed after the first use water was leaking onto the floor. Anyone have similar problem and possibly a fix? Thanks.
Madmax0527 is offline   Reply With Quote
Old 05-31-2009, 10:09 PM   #2
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
If you post a pic or give more information...it may be helpful. Not sure of your shower type. I found my Salem shower leak was coming from under the threshold. Putty wasn't continuous, and water found it's way under and through. Pretty easy fix.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 06-01-2009, 04:05 PM   #3
NWJeeper's Avatar
There is a whole thread on the same subject here on the board that isn't that old. Do a search for "shower leak" on the forum.
Ed & Wendy
www.nwjeepn.com
Old 06-03-2009, 08:31 PM   #4
firedude01's Avatar
we had same problem had to recaulk all around the shower wall. haven tried it since keep your fingers crossed ..
firedude01 is offline   Reply With Quote
Old 06-04-2009, 07:41 PM   #5
AKA KE2DX
Don and Elaine's Avatar
We had a 2003 27Q and one of the first things to go was the shower curtain. I replaced it with a Bi-fold shower door (I think we purchased it from camping world) that was just the fix! Never had a leak again after I caulked the the leading edge of the shower where it meets the bi-fold door. I also seemed to increase the interior of the shower area (no shower curtin in the way) as you shower. It was fairly easy to install and took about 45 min to do.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
Old 06-05-2009, 07:21 AM   #6
Mine was holding water in the channel at the bottom of the glass door, and when you opened the door, gravity made it run out all over the floor! We put a towel on the floor, now! (lazy) Randy
cherokee
