Old 08-31-2018, 09:57 PM   #1
Slide not flush
Hi all,
Just noticed that my slide doesnít sit flush against the trailer at the bottom on both sides. The top of the slide is fine. Because of this the inside tends to go down towards the floor almost touching it. The rails on top and bottom along the slide are clean and no signs of being striped or heavy wear. I have done the slide in and out 3 times according to some video online. Still didnít fix. Any ideas on how to realign the bottom to the top? Click image for larger version
ID:	185050Click image for larger version
leonards is offline   Reply With Quote
Old 09-01-2018, 09:21 AM   #2
SeaDog's Avatar
This is not unusual the key is does the slide seal out the weather when extended or retracted. You should have at least 50% compression of the seals for a good seal. If it seals adjusting to fit the wall tight when closed may have an adverse effect on the seal when in the open position.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-01-2018, 09:28 AM   #3
Supplying the MFG and Model /Type of the slide mechanism will help with Adjustment Information! Youroo! !
Old 09-02-2018, 12:39 PM   #4
Itís a 2016 Grey Wolf 26DBH, donít know what the slide mechanismís called but hereís another pic.Click image for larger version
Old 09-02-2018, 12:44 PM   #5
CZNEDY's Avatar
You have a lippert, schwintek in wall slide system. Not uncommon for the bottom to be out a little more that the top. There are plenty of videos on the LCI website for the schwintek slide out
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
flush, slide
