That ratcheting noise is the nylon drive gears jumping the teeth on the slide rack when the drag on the rack exceeds the spring tension on the drive gear. This is "normal" when the slide is "full in" and "full out" though if you over do it it will prematurely wear out or break the nylon gears.
As capucine stated, if this is happening while in transit; you may have a serious problem. the gears may already be worn to the point where normal drag on the slide makes it skip teeth, the slide may be out of rig, or your gears may be missing teeth.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
