Old 10-05-2016, 07:12 PM   #1
Tyler_13's Avatar
Slide top seal?
Name:	ImageUploadedByForest River Forums1475712364.051296.jpg
Name:	ImageUploadedByForest River Forums1475712418.592213.jpg
Is the top of the slide seal suppose to look like the second picture? 2/3rds of the slide has a good seal with an edge that kind of comes up and holds water out. But on the right side of the slide the top seal is very angled down and doesn't have the curved top part. The slide leaks a small bit of water on the right side next to the bunks and we can't find where it's coming from. Could this be the problem?
Tyler_13 is offline   Reply With Quote
Old 02-06-2017, 11:06 PM   #2
Twistedpairs's Avatar
I can't say it enough, take it in! We ended up taking ours in 4 (or was it 5?) times to get ours fixed. We are now out of warranty and since everything is frozen still don't know 100% if it's fixed. We have had the slide front seal replaced 3 times, the rear once and the top two or 3 times. They finally solved it by putting two seals along the top and upgrading our side seals to the "updated" seals that are shorter and don't get caught in the gear strip. We'll find out this spring if it worked!
'15 26DBH pushing our '18 Ram 3500
Twistedpairs is offline   Reply With Quote
slide
