Slideout leaking
I have a 2006 Forest River Cherokee 5ver, 285B+. I have had a leak on the very outer rear corner of my dinette/couch slide. I pull the drawer under the back dinette seat and the carpet is wet just in the corner. I have sealed the window on the side and rear of the slideout. Took it to a camper store and they did a pressure leak test. They said that they could not find a leak. They did say my slideout side and top wiper seal would leak when the sprayed water directly at them. I would expect that with the water pressure they are spraying out of a hose. But I have looked at the slide wipers and there is NO way it is leaking from a rain and running 3 1/2 feet to the outside corner of the slide, and no carpet from the inside of the slide is wet till you get to the corner. It has been raining alot here in Indiana. I do have 2 skylights ontop the slide but they arent leaking, I checked. I did put the slide in tonight and put a fan on the wet spot to see if it leaks while being put in from the rain overnight or if its dry in the am. Does anyone have any clues?? Thx Eddie
