Old 05-08-2013, 03:31 PM   #1
hadi777's Avatar
Slider manual open
I have forest river gray wolf 27 feet 27BHKS 2012 , please i want how can slider open and close manual ?
Ali hadi
hadi777 is offline   Reply With Quote
Old 05-09-2013, 08:54 PM   #2
You can manually push the slide in. You should havevtwo people to push on each side.
Jeffhfx is offline   Reply With Quote
Old 05-09-2013, 09:23 PM   #3
VinceU's Avatar
Ali hadi
Attachment 29903
You really need to determine the slide mech type. Some are hydraulic, some electric cable, others rack an pinion operated. There is often a means to disconnect or override the power device, crank or by hand but first you need to find out what you have and then you'll find out how to override it.
