Old 07-31-2019, 01:35 PM   #1
solar ready
My 2015 264l is "solar ready". Just battery charging?
Bluetick1955 is offline   Reply With Quote
Old 07-31-2019, 01:43 PM   #2
Oh boy. That means that there is a battery tender style plug on the outside wall with undersized wiring and no charge controlling device at all.
I have that super awesome useless thing as well. I assumed that by SOLAR READY... I could go buy a 100W solar panel and set it in the sun with a wire running to that solar ready port and the trailer would (you know... being solar ready and all...) regulate, monitor and control charging of the 12V battery. Nope. It is a dumb plug, and it's not the plug or wire gage that you would want to use anyways.
I was totally thinking that they actually built the trailer to be fully solar ready so that I didn't have to learn new tricks or wire in new components. The laugh is on me.
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 07-31-2019, 02:00 PM   #3
Yes the port is to charge your battery. You will need solar panels and a solar controller. There is nothing fancy about the port. It is basically a plug with wires that lead to the battery.
If it is a Zamp plug then the polarity of the wires are reversed from all other companies way of constructing their plugs so you would need a short adapter that switches to polarity for you if you don't use Zamp panels.
Zamp solar panels are at least twice the cost of others out there that you can find.
People will also say that the gauge of the wire to the battery from plug isn't big enough, which is true to run at maximum efficiency, however, I get plenty charge from my 200 watt Zamp panels through that port. Some day I might upgrade the wires and my solar controller but right now I am satisfied with it.
Michael and Pamela
Colorado Springs, CO
2017 Roo 233s
Towed by 2016 Ford F-150 screw, ecoboost, maxtow
Replaced 2011 Ford F-150 screw, ecoboost, maxtow
that overheated every time it towed up hill.
joeuncool is offline   Reply With Quote
Old 07-31-2019, 02:37 PM   #4
Got a recommendation for unit. Just want to keep battery charged while stored. Don't want to keep drop cord laid out
THX
Old 07-31-2019, 02:47 PM   #5
Flybob's Avatar
I would not use anything smaller than 100W panel and a decent charge controller. If you think you will ever add more panels get a controller capable of supporting several panels. Panels should be about $1.00 a watt and about $30.00 for a controller.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-31-2019, 03:17 PM   #6
CincyGus's Avatar
Best thing I've thought of to utilize it is to buy the plug that fits it and wire it to a 12v adapter socket to it so I can use car chargers to charge cell phones. It's basically a marketing gimmick with little practical application due to the small wire size and lack of a controller. Maybe useful if you want to put a 20-50w battery tender type solar panel on it to reduce parasitic draws.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 08-01-2019, 08:11 AM   #7
Yes I think that's what i need. When I park the battery goes down and monoxide detector beeps and just want to keep battery up in case need to turn on light or something
Bluetick1955
2015 Cherokee 264L Limited
Old 08-03-2019, 06:21 AM   #8
Would it be safe to buy a 50W solar panel and plug it directly into that solar not-ready port with no charge controller and let it live hooked to your battery 24/7 while the camper is dormant?
I was of the impression that I would be doing harm to my RV battery if I attached unregulated power to it such as that, and that a charge control system really needed to be in play to safely attach solar power to the battery.
Old 08-03-2019, 06:48 AM   #9
Why not install a battery cut-off switch?
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 08-03-2019, 06:50 AM   #10
No. Without a controller/regulator, when the panel isn't charging, it will actually become a 'load' and drain the battery.
Old 08-05-2019, 01:41 AM   #11
If you don't use a charge controller, you will damage your battery. Most panels > 10W or so can output far more than 12V when in full sun. That will destroy your battery quickly. Charge controllers are necessary, and they're not that expensive.
Those solar ports are pretty much useless, unless you can trace where they're wired to and add a charge controller as close to the battery as possible. In most cases it's easier to just plug the panel into a charge controller and use alligator clips, or ring terminals to connect it to the battery. You want the controller as close to the battery as possible. Otherwise, it won't charge efficiently.
2020 Cherokee Grey Wolf 18MT
TV: 2014 RAM 1500 5.7 Hemi
campermatt is offline   Reply With Quote
Old 08-17-2019, 01:56 PM   #12
Joeuncool
Thank you for your info.
I have non Zamp 100 watt panels with a control panel.
You speak of an adapter to convert to Zamp system. Can you elaborate?
Vince
Vbodnar is offline   Reply With Quote
Old 08-17-2019, 02:18 PM   #13
Correction. 100 watt solar
Old 08-18-2019, 11:39 AM   #14
Senior
Originally Posted by Vbodnar View Post
Joeuncool
Vince
I believe this is the connector you are looking for.
Nilight 10 Gauge 2 Pin Quick Disconnect Harness,Heavy Duty SAE Connector Bullet Lead Cable,2 Years Warranty https://www.amazon.com/dp/B0057ZQJ12..._v1xwDbN359J4F
You should be able to determine how the Zamp connector is wired with a multimeter then connect your controler directly to the end of this connector that is the same as you discovered with your meter.
sailski is offline   Reply With Quote
Old 08-18-2019, 05:56 PM   #15
mdstudey's Avatar
Joeuncool
Vince
Use a multi meter and test out your connection first. I have a Zamp on my 2015 23BD and it was NOT reversed. Another thing is to find out what the AMP rating is on the trailer connection. I have seen the Furrion solar port is 10 AMP. Not sure what the Zamp is but I am going to be connecting the controller directly to the battery.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
mdstudey is offline   Reply With Quote
Old 08-24-2019, 05:51 PM   #16
Thank you uncooljoe and sailski
solar
