Old 07-26-2016, 08:22 PM   #1
Some dumb questions from a novice
Hi all! Purchased a 26DBH last month, have already had it out on multiple occasions. As such, I have accumulated some questions.
A/C - mine seems to be terrible. It's hot outside and I only have the 12,500 BTU model. The air coming out is cold.. but doesn't seem to come out fast enough to cool the entire unit. If l close off the ducting and close the doors to the bedroom and bathroom, it does finally manage to cool off a bit but I am wondering what kind of project I would be looking at to upgrade to a 15k BTU. I've also heard good things about reflectix, but looking for input on that.
Battery - the last 2 times I went to pickup the trailer, the battery was completely dead. Is there some sort of shutoff switch or anything? Also, is there a way to add a second battery so I can watch TV without running the generator? I like to watch TV when going to bed, but I am also a late owl, don't think my fellow neighbors would appreciate that very much.
Fridge - it takes forever to cool down. Is this normal? Which should I use to cool it off the fastest, the propane or electric?
Dumping - when at a place with full hookups, do you leave your black water open or let it build up and dump all at once? Also, when we got the unit, it came with some sample packets for the black water. It says to drain the tank, then add the packet and add approx. 2 gallons, then repeat after next time its drained. Can someone give me best practices on this? Ive also seen little stands for the black water hose.. what is the purpose/need for those?
Maintenance - what are your suggestions for keeping this beast in tip top shape?
Thanks for your time, sorry for the long winded post!
jhenretta is offline   Reply With Quote
Old 07-27-2016, 06:40 AM   #2
I have the 27DBH and it takes a while to cool down . I always open the air dump to make it cool quicker.
The refrigerator is what it is. I usually run on propane starting the afternoon before departure and switch to electric once set up.
I installed me a battery disconnect switch near the battery and turn it off when in storage. Just remember to have it on when traveling. The battery is required for the trailer brakes.
As for the black tank , always leave it closed until it's at least three quarters full or it will pyramid on you. And you don't want that. After dumping I always put about 2 to 4 gallons in my tank for travel so it sloshes around.
As for maintenance , keep the slide seals lubricated and the slide roof clean. Other than that, annually clean roof and check caulking.
Have a great time.
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
gconley is offline   Reply With Quote
Old 07-27-2016, 07:00 AM   #3
TURBS's Avatar
Quick cool dump feature for fastest cool down on a/c
Fridge may take 24 hrs to cool down.
Leave all tanks closed till full
Disconnect battery when not in use "phantom battery draws"
15k a/c will run you around $600.00
And won't cool your camper much if any "quicker"
For the black tank a lot of us use the blue streak, puts chemicals in every time you flush for "no" hassle.
http://www.bluestreakchem.net/
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-27-2016, 07:07 AM   #4
raspivey's Avatar
I don't think you'll notice enough difference in a 15k to justify it. As mentioned, open the dumps on the AC and don't use the ducting until after it's cooled down a little.
If it's been dead twice, you've probably ruined the battery (or damaged it to some extent at least ). If you're always plugged in, it probably won't matter as much but, if you run things off of battery, you may not have near the charge as when it was new. There are some things that are "always on" that will kill a battery in about a week so you want to disconnect your battery when not in use or plugged in. Many trailers have a disconnect switch from the factory now (cheap and easy to install one if it doesn't) and the newer ones seem to be located by the battery on the inside of the frame. Mine looks like a red key.
Yes, but (especially since you've killed a battery several times) you really need to buy two at the same time and not just add to the one you have. In general, same size, type, and age. Search the forum for 12V and 6V to research some options there.
As to watching TV with battery power...that depends on whether or not your TV is 12V or 110V. If it's 110V, you'd need an inverter in addition to more battery.
Perfectly normal and, like stated before, start it up a day early if possible. Mine takes about 7 hours to cool down. Propane tends to cool them down faster and colder than 110V.
Always let the black tank fill to at least 50% before dumping for reasons already stated.
Just dump them in and add water. It's kind of like Rid X and deodorizer. Helps to dissolve...stuff and keeps it from stinking.
The generic manual usually contains a maintenance schedule. Follow it. You should also have received a big stack of manuals (I'm assuming it's a new trailer ) for everything installed in it. Read through them. They will list maintenance instructions for everything down to the axles. Reading through will also help in the event that you have a problem on the road and need to troubleshoot or fix things. It rolls, bounces, and vibrates...sometimes things break.
Any questions, feel free to ask.
Old 07-27-2016, 08:14 AM   #5
Fulltime family RVer
See if this helps - expand the part about "At a campsite that has sewer hookups":
Learn To RV: How to Dump RV Tanks (it's not so icky!)
As for the little stands, people believe that they help you attain a proper slope from the camper to the sewer hookup at the site. In a couple of hundred nights of use, I've yet to have a problem without using them. Once, having your sewer hose off of the ground was required (at a park in Las Vegas).
If you're somewhere for a while, they can help to keep from marring the grass with your sewer hose laying on it. I'm really considering one for just this reason:
Old 07-27-2016, 08:24 AM   #6
JustB_Rad's Avatar
I put reflectix insulation in the bunk windows and in the front bedroom windows for our summer trip when it was 96 degrees and it helped SIGNIFICANTLY! Plus it stays nice and dark in the morning!
The fridge will take a while to cool down, and if you still have problems, you have to move the thermester on the fin in the back of the fridge. Up will make it colder, down will make it warmer. It is on the fin tight, so it takes some gumption to make it move.
I also just installed a battery cutoff switch this spring because all the ups and downs last year killed my battery.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 07-27-2016, 08:28 AM   #7
BandJCarm's Avatar
I actually like to get the sewer hose off the ground. I have one of these:
https://store.lci1.com/flowdown
To be honest, I don't use it if I'm stopping for the night. But if I'm there for a few days, I do. It is easier to set up than it seems it'd be from the pictures.
When I don't use it, invariably I have to lift the sewer hose to get it to flow.......meaning it's hard to get a 'heavy' hose to be all downhill from the cap to the sewer drain. With the supports, it never has an issue.
I am throwing away a Rhino sewer hose because it has pin holes in it. The only place I can think of that it got those holes was lying on gravel, or maybe a rock in the ground, when I used it. It lasted 3 months. The support system keeps the sewer hose from exposure to anything ragged.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-27-2016, 08:38 AM   #8
MaineCampingFan's Avatar
Welcome! All good advice given above. You'll find there are some pretty squared away people on this forum, always willing to be helpful. There are the occasional wing nuts
I would add always keep a close eye for water intrusion, whether from above or below. It is the one thing that can turn into a nightmare if not caught. My previous TT was a hybrid purchased used and didn't realize water has made its way to the floor via the outside bottom seam not being sealed. Hence a "soft floor" resulted. Also inspect the roof and the roof seams, at least a couple of times a year. One errant tree branch, hail storm, etc can breach the membrane.
And most importantly: Have Fun!
2015 Freedom Express 246 RKS
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2019: Still Not Enough
MaineCampingFan is offline   Reply With Quote
Old 07-27-2016, 12:41 PM   #9
D_B Travelers's Avatar
First, Welcome! I hope you have many, many fun trips in your new TT! I think most of the previous posts have answered your main questions, but I thought I would comment on the Refletix, or foil insulation. Camping World and Amazon both carry pre-cut pieces for the door windows with Velcro tape for attaching it. I have camped in 106 degree heat for several days before, and the AC needed some help. We went to Home Depot (any big box store) and bought a roll of the silver foil material for about $11 I think. Then picked up a small roll of Velcro. We have foil for the door windows when needed, and on both small windows either side of the bed. A lot cheaper that buying for one window at a time and I have a LOT left over. Yes it does help considerably. We have a 15K BTU and 13.5K BTU unit on our trailer and it still takes a couple of hours to cool down in 95+ degree heat. Be patient, it will get there.
You didn't say if this was your first RV, but if not a few hints on keeping it in good shape. Remember we pull these down some very rough roads at times, and into a near-hurricane head wind always. Pretty tough environment. Be sure to pack the correct type of screw driver bit to fit your cabinet door hinges, trim on the trailer, and a general set of tools. I also pack some Gorilla tape (much better at sticking and staying than Duct tape, IMHO) in clear. It doesn't leave the goo residue if you have to use it and it really stays put. Be sure you have the jack and tools needed if you have a flat also; check for Trailer-Aid on this forum for in-depty discussions on jacking up your trailer.
Lots of great information on this and other camping forums, be prepared to sort through what is relevant to your trailer and you will benefit greatly. Again...
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 07-27-2016, 12:44 PM   #10
mdstudey's Avatar
I just put the reflectix in our TT last week and what a difference it made. You can get it Home Depot. I could not believe how fast it cooled down.
I just bought the hose holder. Hopefully it won't take two of us to empty the tank now. Before we would have to keep lifting it off the ground to keep everything moving.
I am still a newbie but starting to get it down.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
mdstudey is offline   Reply With Quote
Old 07-27-2016, 12:50 PM   #11
BamaBob's Avatar
<SNIP>
Yeah it's a bit pricey but it beats hands down the slinky stands I have seen on the market. Plus it is the only game in town if you have to go over a railroad tie (like I did in one park) or make a 90° turn (as I had to in another CG)
https://www.amazon.com/Lippert-Compo.../dp/B00I5LWSRE
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 07-27-2016, 12:52 PM   #12
Problem with that is us folks with 2 sewer connections. Getting them aligned in the wide variety of sites seems like it would be a real pita.
I've had to go over cement lips around the sewer connection- I don't see how a railroad tie would be much different.
Old 07-27-2016, 01:03 PM   #13
SailorSam20500's Avatar
I'm looking to buy a new trailer. Found one at a local dealer that has a 13.5 K AC. Asked about cost to swap to a 15K. Quote was $1300! Total for several changes we wanted made it significantly lower cost to order a trailer and have the factory install the stuff.
Al
Save the Earth. It’s the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 07-27-2016, 01:31 PM   #14
Frig. cool down.
I always keep in my home freezer, 4 or 5 frozen 1/2 gallon jugs of water and 8 ice cube trays filled and frozen and put them in the MH fridge and freezer to help it cool down faster. Also, make sure the stuff you are packing in the frig is precooled and do not pack the frig so that the air cannot circulate. With the ice it takes hours to cool rather than days.
markb422 is online now   Reply With Quote
Old 07-27-2016, 01:46 PM   #15
Cheap 12v TV
I just picked up one of these to replace a 13" version I got about 6 years ago. It is powered by a "power brick" that plugs into the wall, but actually runs on 12v so you can splice a cigarette lighter plug or something onto the end, and run it directly on 12v so you don't need an inverter. It is less than $80 with tax if you sign up for a Rite Aid discount card (which is free).
https://shop.riteaid.com/craig-19-72...-count-9027163
Cathcartww is offline   Reply With Quote
Old 07-27-2016, 02:13 PM   #16
dea49's Avatar
It's 98 degrees outside here and it took my A/C only about and hour to drop my camper (Rockwood 2603) to 75 degrees. Last summer I couldn't even keep it at 80 during the day unless I used the dump with fans to circulate it around. Cool air was coming out of the vents but it seemed a lot less than what the dump was providing.
While replacing the tank vent covers on the roof I found a major problem. The A/C was running inside and when I removed the cap, cold air shot out. Suddenly and idea popped into what little brainpower I had left from being in the sun all day. I crawled underneath the camper, put my arm on top of my black and grey tanks and felt cool air coming out there too. The factory had cut right through the ceiling duct when they installed the tank vent pipes and a lot of my A/C was just dumping outside.
To fix that I bought a can of expansion foam and on the roof applied it around the vent pipes below the ceiling duct channel and then above it before reinstalling the vent caps.
The 2nd thing I did was to remove the inside A/C cover, I saw they had just cut into the side of the duct channel and the air coming out of the unit was hitting flat surfaces creating a lot of turbulence. Using the can of expansion foam I filled up the whole area around the duct channels and when it cured used a knife to cut out new channels from the A/C to the ceiling ducts, being careful to lead the airflow at angles to allow for a smooth flow into the ducts. Before reinstalling the inside cover I covered all metal supports with the foam, trimmed it clean to prevent any sweating caused by the cool air.
Now the vents have more air coming out of them on low than they ever did on high before. We never use high anymore except for initial cooling.
The attached pics show a little. I even supported the roof with a metal bar because it was leaking when it rained because the roof panel was bending down due to the A/C seal.
ID:	115537   Click image for larger version
dea49 is offline   Reply With Quote
Old 07-28-2016, 05:25 PM   #17
The freezer will cool 1st when you turn on the ref. Only after it's happy, will the lower part start to cool down. So as suggested, we have 3 one gallon jugs of ice we keep in our deep freeze and put those in the freezer to get things started. When loading, also load items pre-cooled in your home ref. Another key to to park that side of your unit in a shade which will cool the air flow going over your fins. As far as using a slinky. Any type is fine. I have a bad back that was giving me issues on one trip. When I dumped the hoses, there was enough lifting to put my back over the edge and had intense pain the rest of the trip. No fun! ! The biggest thing is to have fun. You're going to make mistakes . . . we all do and have. Just learn from your mistakes and laugh at them. Enjoy.
texasbuckeye is offline   Reply With Quote
Old 07-28-2016, 09:15 PM   #18
Wow... so many great tips in here. Id like to thank all of you for your contributions to this thread... What an awesome community!! Cheers!
Old 08-01-2016, 03:12 PM   #19
BamaBob's Avatar
When we had the 5er, we had 2 connections as well. I just positioned the flow down in the middle and favored the gray/black tank. Popped the WasteMaster off the Black/Gray and on the Galley. It was pretty easy to do.
now (thankfully!) I only have one central sewer connection
