Old 08-24-2016, 10:28 AM   #21
Is it possible to increase the tension on the slide topper?
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 08-24-2016, 01:08 PM   #22
NMWildcat's Avatar
Yes. They should all have an adjustable spring. Higher tension, especially on our longer toppers, seemed to make no difference in the annoying flapping.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-24-2016, 08:28 PM   #23
We have had slide toppers on all of our trailers and now with the 3 slide sun seeker its great to have all of them with toppers. Sure one of them tends to pool water , but the other two do not. however you can tighten the spring to take some slack out of the topper. Its amazing how much debris can build up on the top of a slide and once you put it in you can sure raise some problems with the top gasket. Anyway once in a while with the slides out when I am cleaning the roof I take a mop and clean off the tops of the slides under the topper. Just a bit more maintenance but its better than replacing the top gasket because some tree branch got caught up in it.
Brandon2
2014 Sun Seeker
2500TS
brandon 2 is offline   Reply With Quote
Old 08-28-2016, 07:22 AM   #24
MCTroy
Definitely agree with having the side toppers. Besides keeping the sides clean, they also help keep the sun off. Every little bit of extra cool helps in the summer heat. We don't have any flapping with our toppers and cleaning is easy.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
2016 camping: Lost count, but never enough.
2017 6 nights and more reservations made!
MCTroy is offline   Reply With Quote
slide, slide out
