Old 01-25-2017, 07:54 AM   #1
Step lights on 26dbh
Not sure why but the 26dbh only comes with the led strip under the main entrance and the awning...has anyone found the same strip to put under the bathroom door steps?
Tngahan is offline   Reply With Quote
Old 01-25-2017, 08:00 AM   #2
Georgia Rally Coordinator
aceinspp's Avatar
You can buy a roll of the lights and cut to fit. Usually Amazon or evilbay has them. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 57
aceinspp is online now   Reply With Quote
Old 01-25-2017, 08:37 AM   #3
JustB_Rad's Avatar
I bought mine right before they started putting hose lights on them, so I added mine. I just bought a 8" weatherproof blue LED strip from Walmart.
https://www.walmart.com/ip/Seasense-...-Blue/16651498
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 01-25-2017, 10:14 AM   #4
Thank you! Has anyone replaced the blue with clear/white? Was this difficult?
Old 02-04-2017, 06:48 PM   #5
smnavalley's Avatar
That's a great idea! Would you mind sharing a photo of the finished product or describing the exact location you placed the strip? Also, were did you tap into power?
2013 Ford F-150 5.0 Super Crew 4x4
2017 Grey Wolf 26DBH
smnavalley is offline   Reply With Quote
Old 02-06-2017, 08:33 AM   #6
JustB_Rad's Avatar
I can't get any pictures for you until spring because the camper is in storage this year (normally its sitting alongside the garage). I mounted the above mentioned light to one of the cross members of the stops with self tapping screws.
For Power:
I also added LED's over each of my stabilizers for nighttime setup, but wanted the ability to not have all of them on...so I added a new bank of 3 switches. 1 for the step light, 1 for the front lights and 1 for the rear lights. I ran new wire for the positive feeds up the inside wall of the camper where everything else runs (right behind the sink). I tapped into the power for one of the other switches in the cabinet behind the switches...I didn't run a ground up (because of space in the existing hole in the floor for wires) and instead each of those feeds has its own ground to the frame.
Old 02-11-2017, 12:12 AM   #7
smnavalley's Avatar
For Power:
Thanks for the step by step! Greatly appreciated and thanks for the tip about lighting the stabilizers. You're a genius!
light
