Old 06-29-2016, 09:04 PM   #11
trbomax's Avatar
What ever you use,do it with a MICRO FIBER rag to help eliminate the possibility of more scratching.
trbomax is offline   Reply With Quote
Old 06-29-2016, 09:23 PM   #12
x2 on the WD-40. We pulled all our stickers off and this is what we used for easy glue removal.
glb6 is offline   Reply With Quote
Old 06-30-2016, 08:00 AM   #13
To remove the glue... Goof off, Stoner's Tarminater, Carpro Tar X, and/or clay bar. If it's really thick, I thin it out with a plastic razor blade first.
To remove the scratches... Should be able to get away with hand polishing since it is confined to a small area of the trailer. Your local auto parts store should carry compound and polish. To be as safe as possible, use this on a foam wax applicator and rub in a circular motion. Use pressure as needed.
I detail for a living and see several cars a year that had a magic eraser treatment.
Muddyoldgoat is offline   Reply With Quote
Old 06-30-2016, 08:09 AM   #14
Just buy a can of acetone. No elbow grease, erasers, mico this or that. Very low smell, unlike lighter fluid. No residue. Apply with paper towel and your done.
Old 07-01-2016, 05:56 AM   #15
Thank you everyone for the suggestions...WD40 and 20 mins of scrubbing and all of the residue is gone!
Tngahan is offline   Reply With Quote
Old 07-01-2016, 06:20 AM   #16
RSchleder's Avatar
There are several good products in a tube that work well to remove small scratches. One I have used on my Corvette (fiberglass) and my Ram is "Scratch Doctor" with excellent results. Just experiment a bit by using light pressure when rubbing in a circular motion and you'll be pleased with the results! Rewax after you repair the scratches and you'll be good as new.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-01-2016, 06:34 AM   #17
Ford Idaho's Avatar
Great, now grab that WD can and your fishing pole, spray a little on your bait and kick back.
Old 07-01-2016, 06:53 AM   #18
Sky&Scuba
kendive's Avatar
Originally Posted by Black View Post
Give WD-4O a try...it works great for that purpose !
I also use WD-40. The new Catalina 253 RKS had www.coachman.com/rv on the back I had to remove it... Looked Terrible. Also removed all the dealer stickers.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-01-2016, 07:02 AM   #19
Flybob's Avatar
Will a good wax remove the little scuffs in the fiberglass from the magic eraser? I can't feel the scuffs but they are visible to the eye
Goo Gone let is soak for a minute or two.
The magic eraser is a marketing genius. It is really nothing more than a scrubbing pad with a fancy name which somehow transforms it into a unique cleaning product. I do not recommend using it anywhere you would not use a scrub pad.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-01-2016, 08:32 AM   #20
WFD
Make sure to apply a wax to wherever WD40 was used...the WD40 will have stripped away any wax that was there previously.
WD40 also works great to remove any tar you may encounter in your travels.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
