11-15-2010, 10:01 PM
Surburban furnace problem
OK heater wont stay lit. But If I put tape over the cold air intake on the outside of my unit it works flawless. Remove the tape heater goes out instantly. And ideas? Its not power supply, not low gas pressure. Its something with airflow. There are no mud dubber nest inside the tubes that i can see.
 id rather be in my hammock
11-16-2010, 07:57 AM
Lou Amadio
Trouble shooting guide
Try to see if this can help:
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
11-16-2010, 08:48 AM
Are you completely covering the intake or just partially? sounds like a mixing chamber adjustment problem. Possibly from a spider building a web inside the burner throat.
Grand Surveyor GS-280 Pushing a 2500 Mega-Cab CTD!
WOW it's already 2012! Gotta go campin
11-16-2010, 02:02 PM
Lou Amadio
Or a "stink bug" cacoon, They are very tightly woven.
11-16-2010, 06:11 PM
OK I pulled the unit completely out. There s nothing inside . not even a trace of insects. Took my craftsman yard blower . ( just happens the nozzle matched ) Blew from the intake side for 2 minutes then the exhust side . Nothing came out. Reinstalled. Hit the switch wont lite. Reset covered 2 of the 3 intake holes she lite up and ran wonderful.Remove the tape goes out again.
Seriously considering electric insert and 50 amp service.
11-16-2010, 06:27 PM
Lou Amadio
Page Six
Look on page six of the troubleshooting manual.
In my opinion, your problem might be the "Flame Sense" circuit on the main board is bad.
It works by looking for ions in the air flow from the flame being lit. No flame, no or "not enough" ions in the air. With normal air flow to the burner the sensor may not be seeing "enough" ions to convince the main board that the fire is lit and shuts down the furnace.
Blocking some of the incoming air might allow more ions to concentrate at the sensor and the main board then is happy and allows the flame to keep going.
This company carries circuit boards for most of our products that use them. Dinosaur Electronics Home. High quality circuit boards for RV appliances.
11-17-2010, 07:32 AM
I think I'm confused. Are you covering the combustion air intake on the outside of the RV or are you covering some of the return air holes on the inside of the RV but the outside of the furnace?
11-17-2010, 08:13 AM
Lou Amadio
"Cold air intake on the outside of my unit" I took to mean the combustion air intake.
Since the Combustion air fan and the Blower air fan are on a common shaft motor, I can only assume that restricting the airflow to the burner allows the flame to light and stay lit.
That could be a problem with the flame sensor not detecting the fire that is there or a too lean mixture setting that needs much less air to stay lit.
Since it worked before, and he did not indicate he changed any settings (if the air feed tube was restricted you would have an over rich mixture not a lean one) I am leaning toward a bad board.
11-17-2010, 08:55 AM
["Cold air intake on the outside of my unit" I took to mean the combustion air intake.]
I did too at first but then he said,
"Reset covered 2 of the 3 intake holes...."
Since all the units I've seen have only one intake hole for the combustion air inlet and multiple holes for the return air, it gave me pause to think.
11-17-2010, 10:10 AM
Lou Amadio
The intake hole has a tripod shaped support. I assumed he meant he covered two of the three triangular shaped inlets in the round inlet pipe.
I could be very wrong though. Flirtypup needs to clarify.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 548 |
| 107 members and 441 guests |
| 0721SSROO, 1stvcross, 4bnabird, 4Jeeperz, 4runner freak, acadianbob, Adony, Barnman1, BigKidzFun, bignugget, bikendan, bka4tcu, BlakeB, BOBFIDY, bowtang2001, brookside, Browndog, bumper, Cafjackracing, caper, cdbus, cgreen1509, cgsparks1, chof16, cllecr, comfun1, Cowracer, cyclepuck, danred, darkcloud, daw592, ddurnell, deerslayer, Dennis and Julie, dezeldad, donn, drb1256, Drmstx62, dunnnc, EastlakeRoo, extremebike, flc, Flying dutchman, fordmantpw, FreedomTracker, frfan, GeorgieGirl, gerrym51, gimp425, grhodes50, herk7769, hjgrimm1, Hob, hoovercab, Indy Steve, Itsthetwoofus, Jeep4Two, JMF, JoeR, Joseph5410, jtstromsburg, keep camping, kegoneill, kgmat, kootenayrig, Kricket, KRS, Laura, lemoj1, LFugate, Lonewolfcry, lowbubba, mayorvic, mcbride5, melbornj, Mickey1, MREZ, NeilM108, newby, nuisance, pg_rider, popeye59, RalphieG, redfox217, Redheaded blue tick, Reneedann, rkswyo, Rugged Brown, Sailfish Bret, Skabi, skipper194242, softwarejoe, Tee, tessval, THELMALOUIE, Titleguy, tking01_2000, torben, travyp, treadwelll, TTNewbees, vp22er, VTX Al, wayne anthony, Wiscampsin, wolfpack21643, yvesm |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
